quick help
ChairmanMaoSaysRTFM
Originally Posted by Mike_McCready
Anyone??
Can I just spray carb cleaner in there? Seriously not looking to ruin my engine today, thanks for any help you can offer me
i'm also not too familiar with the TL IM construction, but make sure you put some papertowels down in there in the outlets to the chambers to soak up the liquid.
SSTS
Did you clean that on the car like that?????
Originally Posted by SatinSilverTypS
that looks about all you need to do for the IM and TB, but if you spray cleaner in there don't let it all run down into your cylinders or you could run the risk of hydrolocking the engine. i don't know exactly how much liquid it would take but why chance it.
SSTS
SSTS
Originally Posted by fsttyms1
you would have to remove the part pictured (upper IM) to clean it. There is no way of sticking any thing in the ports to stop the fluid from going down in the engine with out removing it.
Anyways, maybe I'll finish the job at another point
see the 6 small holes in your 2nd pic. Those are what gets clogged and need to be cleaned. You will want to remove the intake (very easy 11 bolts) and a few hoses and wires) t o clean it properly
ChairmanMaoSaysRTFM
SSTS
gotcha. i'm going to tear mine apart this summer to get familiar with it and clean it out. i remember having to clean the intake manifold on my SHO. goddam that was a pain. the manifold runners had sweeping curves that were a pain to clean properly. the TL IM seems much friendlier.
SSTS
SSTS
Sippy Cup (x2)
its very easy. There isnt much to clean in them, Most of its the 6 small holes that need to be cleaned out. They are what usually clogs up triggering the P0401 code
TLguy42
09-26-2015 11:27 AM
