Questions on some mods
hello there guys i have a few questions on the TL. i have a 2000 3.2 tl and heres my questions:
1) Are the Obx headers C.A.R.B Legal and can you pass smog if you have them on along with a AEM CAI?
2) Are the bypass valves necessary to go with the AEM CAI? and what difference does it make with the bypass valve? I heard it makes it sound more aggressive and is used when it is raining so the filter doesnt suck up water? Am i right?
3) Whenever i run a bump something makes a noise. I am thinking it might be the brake alignment or the struts or shocks.
4) How many of you guys have the Sarona bodykit on your TL?
I am greatful for all the answers, Thanks guys...
2. Bypass valves are not necessary and unless you really plan on driving through flooded streets often I wouldn't worry about it. The bypass valve could potentially be very dangerous if you don't clean it often enough. There was a guy from a-cl.com that had his bypass valve fall apart and get sucked in through the CAI into the throttle body. The result was his throttle body got stuck open and his car wouldn't stop. The CAI alone won't suck up any water when its raining ... its really for when you're driving through flooded streets.
3. Sorry, can't help ya there ... Can you be more specific?
4. No Sarona, imho its too flashy. I'm probably going to go with the OEM kit personally.
it makes a cranky noise like somethings loose. I go very slow on bumps
I have the AEM V2 CAI w/o a bypass filter. It's not that loud when you're cruising at low RPMs, but it roars when you floor it. I drove in a thunderstorm right after I installed my CAI w/o any problems.. I don't think the bypass valve it necessary.
BoricuaTL
04-08-2016 01:08 PM
mrkingstonvi
02-22-2016 01:53 PM
