Question: WetSanding Headlights
Hello all, yesterday i decided to wetsand my headlights.. I went out and bought the following:
1) Pack of 1,000/1,500/2,000 Grit Wet/Dry Sandpaper
2) Meguiar's PlastX
3)Foam Applicator Pads (dont have a machine yet)
Here is what i did...
1)Soaked the sandpaper in water for 15 minutes
2)Hosed headlights
3)Sanded for about 4-5 minutes with each grit, drying after sanding
4)After all 3 grits, headlights became cloudy, then used a foam applicator w/ PlastX and rubbed in circles along headlights.
The final result was not super clear.. It still is a bit foggy. And my headlights werent that bad to start with.
My question is.. WHAT DID I DO WRONG?
2) Meguiar's PlastX
2)Hosed headlights
Avant Garde Wheels
starting with lets say 800 grit if there is..
sand this way.. ----->
next with 1000 grit... sand this way <------
next with 1500 grit.. sand this way ^^^^^
next with 2,000 grit.. sand this way vvvvv
get it?
and i used 3M rubbing compound and rubbed that in hard.. then used Megs polish to clear it up more... never have i even touched plastic X cuz that thing sucks... for me...
and you must keep the sandpaper wet.. even headlights...
and i usually use warm water to soak my sandpaperrss
get it?
^ actually if you go all one direction its easier to hide the scratches.
Op. You just didnt polish hard and long enough. It will take a lot of elbow grease to polish that out. You could start out with something a little more aggressive as for polishing first then go to what you used.
AZ Community Team
Received 7,771 Likes
It's the polish. You've really got to work it to get to break down and do it's job.
As mentioned, when wet sanding, keep the area wet the whole time you are working.
AZ Community Team
Here's a DIY:
G-085: DIY: Restoring Hazed/Cloudy Headlights
https://acurazine.com/forums/3g-tl-2004-2008-93/g-085-diy-restoring-hazed-cloudy-headlights-710313/
I think its the plastic x thing you used. I just did mine a last week when I blacked them out. I used 1500 and wet sand, then switched to 2000 and wet sand. I didnt soak it in water. Once it dried up, it was foggy as heck. 3m rubbing compound removed the fog and polish to well.......polish it up. I highly doubt you will need to resand, just 3m/polish. I'm sure you can just get 3m if you are limited to funds, that should clear up your headlights but it wont be as polished. Before on my old car I did the same thing and all I had was NUfinish car polish and I used that, it got out all the foggy on the lens. You can pick that product up at any auto store.
Need an OEM lip kit on my
I just did my friends mom's car. They came out brand new. I started with 600 and then moved up. They were EXTREMELY YELLOW
Also a buffer with a wool bonnet helps alot. If you buy one, you can do other people's headlights and charge them a decent fee like $30
^ ya.. when i was buying the supplies @ pepboys, they told me it is usually 90$ to clear headlights.. and a guy was offering me half off for 45$... so if i get good at it, maybe 40$ should do it. The best part is, you can do this on any car and not just one = MORE $$$$
i went to autozone and heres what i picked up.
1) PlastX $6.99
2) Turtle Wax Rubbing Compound $3.99
3) Turtle Wax Polishing Compound $3.99
And then from Costco i got a 50 pack of Green MF towels
I polished and rubbed as hard as i could, and still not satisfied.
1) PlastX $6.99
Keep It Simple in
Wetsanded and washed my dads 98' Ford Winstar headlights, 30 mins ago, for his birthday.
Steps: 1000 grit wet sand
1500 grit wet sand
2000 grit wet sand
Dry
Buff with Turtle wax Polishing compund
Finish imperfections with Megs Ultimate Compund
Remove with microfiber cloth
wax
done!
Took these pics just for you. The right headlight is PRE-SANDING!
(Yes that is a Cold Air Intake in my dads minivan, lulz!)
1500 grit wet sand
2000 grit wet sand
Dry
wax
done!
thanx slushyyy.. btw, you did this by machine or hand? LOL at the intake. Before you do the other one, i need like a vid on EXACTLY how you did it after you sanded em. I keep getting a lil cloudy at the end result.
Keep It Simple in
*The sandpaper has to be constantly wet when sanding. Not just soaked for 15 mins.
