Question On Seafoam...Where You At 01tl4tl
Imma Move to NJ the 17 or 18 or 19th of Sept. Just Thinking If I Should Seafoam Right before I Leave to NJ. As In...Put The Seafoam in my car..Let it sit for the 5 or 10 mins or whatever then from there Get on the highway to Go to NJ. (Im in NC).
well you'd have to be driving spiritedly, and in which case you'd be spewing out so much white smoke you couldnt see behind you. which would cloud up and block up 3 lanes, and then the PoPo's would come for you
For the desired effect of hot clean out, you need to do 20 minutes of 4000 rpm driving with up and down the speed and throttle range- using vtec a lot- not something I would do with a car full of stuff
Do the cleanout of the intake a few days before- and throw a can in the gas tank for good measure- it will clean the injector spray pattern on the trip
Originally Posted by ThreePointTwoTeeEl
I'll Prolly Do Night Driving Cause During The Day I get Tired. Yea Im Weird.
You will get better gas miles at nite since there no traffic an you can drive little faster with open highway
If you want to be a fanatic about it- if first time, do it again in 2000 miles and run some in the crankcase then and change oil
If you buy off brand gas- Tier 2 as its known in the industry, run some every 2-5000 miles in the tank
Tier 1 gas, with cleaning additives- 5000-15,000- once a year or so
Gas is never going to get cheaper so get all you can out of every gallon
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
just put a can in 1/4 tank, run it down to almost empty then fillerup. i do it every so often just to make sure everything is nice and clean.
