Question regarding indiglo gauges
Yes, i've searched ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I got the gauges from procarparts, my question is, will I still be able to see the warning lights with those gauges? Or does it block all those yellow/red lights?
if it blocks them, then this would suck.
aha! thank you! now i feel better. Cauz i began slapping myself when I thought of them blocking the lights
thanx hzm, by the way, to get to the cluster, just take those 2 screws out and the rest pops out?
Here is a DIY I wrote up. PM me if you need extra verification or help.
http://www.acurainspired.com/forums/...showtopic=2810
Originally Posted by johnny--2k
wow...quick response! Looks good...do they change colors, or is that it?
HZM has the reverse indiglo , i have the full face indiglo. Got the digital inverter to change like 5 colors, i believe.
yeah but, with the regular indiglos all the circles are fully lit, looks too bright and not as classy the as the reverse.
thanx, i like the 'A' on your steering wheel, where is that from?
i havent read the MEET threads, there is a meet? sounds cool. If I will have nothing to do, I'll gladly be there.
i
damn, ive had those same reverse indiglos for like the past six months just sittin in my trunk cuz im too lazy to take it to a shop, and i dont wanna risk destroying my whole gauge cluster.
the meet is on Saturday?
cant make it.
moahdriven, if you do it carefully, i believe you wont destroy your gauges..
its very easy BUT take your TIME! if you dont you will be pulling it apart to do over. use just enough tape to hold the gauges down, use too much and the needles will rub on the gauges and stick, dont use enough and the same happens (personal experiance)
Originally Posted by SMILEY
Those gauges look nice, but will they fit a type-s? Does anyone know if there are any for a type-s? thanks ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
i
Originally Posted by fsttyms1
its very easy BUT take your TIME! if you dont you will be pulling it apart to do over. use just enough tape to hold the gauges down, use too much and the needles will rub on the gauges and stick, dont use enough and the same happens (personal experiance) ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
how can you fully test if the needles dont get stuck? you can rev high, fuel? speed?
im an idiot, please ignore that question.
Hey, before the install, do I have to disconnect the OEM LED? or they stay on with the new gauges?
Also, what connector do I need to test out the gauges?
You can, but i didnt. I think the oem leds can heat up and cause the adhesive to loosen up. But I dont have that problem.
To test out the gauge you can plug in to any thing that is 12v. I tapped the wires to my sunroof or cruise control switch light. So when the parking light comes on so will the gauges.
You might need a tester to find out which wire it is or maybe you can connect to the indiglo pedals you have.. they turn on when you turn on the lights right?
to connect them get a female spade conector and connect it to the back side of the fuse box to #13. its powerd by the lights.
as for what to use to tape it down, if the kit doesnt come with any tape go find some good 3m double sided scotch style tape. it canot be thick at all. the thinner the better,
thanx for the info,
i will probably connect them to my pedals. thanx guys.
I just dont know for ppl with reverse indiglos, did you disable the OEM LED? if you didnt, can you see the OEM light thru the reverse gauges?
peace
peace
you can not see the oem lights thru the indaglo gauges. i did install a toggle swithch to be able to turn off the indaglo gauges though. at night with the indaglo shut off the only thing you can see is the needles lit up
its kinda a bad pic but you should be able to see what i mean
![](http://www.acurainspired.com/gallery/data/f90f2aca5c640289d0a29417bcb63a37/188_p21762.jpg)
thanx guys for all your info
I've just successfully installed them without any complications. It took me about 2 hours to install and test everything out. Its a pretty easy mod as long as you take your time and of course get great feedback from everyone here that helped me!
Thanx again, it looks nice. peace.
i will post a pic a bit later, for the visors i got them from a previous member.....he had away to get them from Inspire Japan.
that was a whlie ago....They are available online on some sites, they go for about 200 bux..
lata =]
lata =]
here are some pix:
![](http://img99.exs.cx/img99/6425/IMG_22.jpg)
![](http://img99.exs.cx/img99/8518/IMG_23.jpg)
![](http://img99.exs.cx/img99/2341/IMG_25.jpg)
woooo!!
here are some pix:
looks great tekno!
btw these are the silver reverse indigo gauges right?
Thank you!
yes, so they look good in the day time too.
have fun
have fun
