QUESTION on PAINTING ENGINE COVER???
#81
Originally Posted by dvsxlt247
Ok, no one on here has specifically told me brands of spray paint i can use for this. Now im a big fan of rustoleum spray paint. Can Rustoleum spray paint from HOME DEPOT do the job perfectly??? Also, will Rustoleum Primer work for primeing the cover????? PLEASE SOMEONE TELL ME EXACT BRAND INFO, cuz i just stopped at discount auto on the way home and they had car paints but not the right color blue that i wana do it. Also, i saw a sandable white primer, but i wasnt sure if thats the primer i needed, cuz fsttyms1 told me to get a HIGH BUILD primer which i didnt see there. But look, will rustoleum white primer and rustoleum Glossy spray paint from Home Depot work just fine??? Also, can i just use some fine grit sand paper to sand the cover down?? I dont have to use a 3M scuff pad right? ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#85
Prick of the month
I posted a crapload of pics in this thread I started.
https://acurazine.com/forums/showthread.php?t=155924
#87
Prick of the month
Originally Posted by VoLLy_1llusioNz
Wow it looks really nice. You followed ALL of his instructions? or did you do something else of your own to make it look that good?
The dark area was Metalcast as well, didn't turn out quite the way I thought it would, but I like it. The cap was like a dark chrome, like the badging on the Lexus Platinum editions if you've seen one. That's what I was going for.
The silver lettering was going to be blue but I forgot to paint it before I ran out of the blue, so I left it the primer color, it comes pretty close to matching the car and makes it stand out more.
#88
You do NOT need to sand between every coat unless you get imperfections (IE.. Runs or dust/dirt) that needs to be removed. Also sanding between coats isnt recommended if your using a enamel finish. The only sanding you need to do is the final primer coat and the final paint/clear coat<-- (if using a 2 stage paint). Also the desired effect can be accomplished with 1500 and 2000 grit as well but if planning on attempting this you will need to buff afterwards with any grit you use
#89
Prick of the month
#90
Originally Posted by 02TLSfan
There were a few imperfections so I had to sand between coats, it was my first try painting anything but a house.
#92
The Metalcast made no mention of a clear coat, I assumed there was no need for one. Next time I paint something I'll keep that in mind.
#93
Prick of the month
That's what I thought you had said before somewhere in this thread. At least I know I didn't forget something. I tried to follow any advice you had given, guess I missed the sanding part.
#94
Originally Posted by Mike_McCready
Well I took the advice toward Metalcast. And it came out FANTASTIC!!!
I painted my AEM CAI as well, but I haven't installed it yet. But here is a picture of my engine/valve cover
![](http://i41.photobucket.com/albums/e283/mikemccready/enginevalvecover.jpg)
Since metalcast is almost like a candyapple did you use a duplicolor white primer?
#95
#96
pissed off!!! yea so I decided to try the duplicolor metalcast on my battery box before I did the engine cover to make sure i liked it and get the technique down and Im glad I only did the battery box. Does anyone know why the paint would dry with a white haze to it? I cleeaned, sanded, used adhesion promoter and then a primer and then 3 coats of color, everything worked fine but the last coat of color dried with a white haze, what a waste of time.
#98
#99
hey
ok so i just painted my engine cover silver. i used three coats of silver and one coat clear coat. i forgot to use primer. will the paint melt or chip off since i didnt use primer?
#100
Registered Pimp
i already got my duplicolor paint with my super secret cool colors but im wondering if i can put like 20 clear coat layers on it to make it super super glossy, or if it will just look like crap?
#101
#102
Hi HawaiiTL,
I am new to this forum and I would like to paint the engine cover as you have done in the future. What brands of paint did you use? Where did you buy them from? Were they all spray cans?? Will the paint fade over time when the engine is hot??
Thx for the help!
Thx for the help!
#103
I did mine a couple weeks ago, and I used the Krylon Fusion paint which is designed for plastic. I used it for my other car and it held up for the 3 years that I had the car.
![](http://img245.imageshack.us/img245/6863/a8fa84f6e8fabv9.jpg)
#108
'03 TL-S NaV SSM
Krylon has silver, but not SSM.
To get the exact color match, try the "Tower Paints" internet store like previously suggested in this thread. They can mix up a custom batch of SSM in a spray can for you.
-Chris
-Chris
#109
Originally Posted by nevets31
Does Krylon come in SSM color? Should I then just use Silver??
Or get the material (nothing more than a pint is needed) from the paint store and use one of these. They can be found at most paint stores and Home Depots etc...
![](https://img299.imageshack.us/img299/5033/0911060927pr1mr5qo8.jpg)
#110
Exquisite One
![Wink](https://acurazine.com/forums/images/icons/icon12.gif)
Nice, I especially like the red stripes on the VTEC badge. Looks very JDM-like.
#112
Exquisite One
Okay, well here's my engine cover painting project. Sorry I didn't start with the sanding/scouring process, I didn't think about photos until I got done with the first primer coat.
I used 2000 grit sandpaper, but you can use basically any grit sandpaper. It is just plastic though, so nothing incredibly rough is necessary. And no, sanding between each coat is not necessary. In fact, if you do sand after every coat, unless you apply close to 10 coats, the paint will begin to fade, not chip, after a few cleanings. **Please remember that when you clean your engine bay with degreaser after this, not to spray and rub the painted parts!** Degreaser is highly effective cleaner and will therefore slowly eat away at the paint. If you want to clean the painted areas, use a hard-surface cleaner (such as Windex) or just a rag to wipe it off and then polish (I personally use Honda's Spray Cleaner and Polish, which is easily found at your local Honda/Acura dealership; costs around $5.00 - $8.00) afterwards.
Here's a before photo.
I cleaned each and every individual par under the hood that had any dirt/grease/grime on it. I then removed the bottom portion of the engine cover and the battery cover. I'm doing this in small steps, to make sure everything gets done right, the first time.
Here's a pic of after I applied the 1st coat of Primer. I do plan on sanding after this dries, but only because there's a couple of corners and edges with a few overspray areas. Otherwise, I would just apply a 2nd coat of Primer and continue. I used Rustoleum's Professional Primer, which I found at Home Depot for $3.79 plus tax.
It's now drying time. More posts to come later today.
#113
Exquisite One
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
![](https://i6.photobucket.com/albums/y212/volly/i%20shot%20er/100_4997.jpg)
Where the hell did you find those headlights? I have got to get them. I've looked everywhere, including ebay for projector/jdm headlights for my girl, but I've found nothing but factory sets. Any help would be greatly appreciated!!!
Thanks Volly, for bad-ass pic!
#114
Meridian
#115
Its not that expensive to just have a body shop paint it for you. Take it two a shop that does alot of Honda or Acura's (maybe the dealership bodyshop). They will have the paint you need already mixed from other jobs. Im sure you can get it painted and cleared professionally for about $60. I happen to work at a dealership so my buddy painted mine (for lunch) but he said it was nothing to shoot it and clear it. Having the cover cleared and baked makes maintainance and clean up a breeze.
![](http://img252.imageshack.us/img252/184/dsc03683sm3.jpg)
#116
i was just bought a can of Dupli-Color Engine Enamel thats "dyno heat tested 500 degrees" blah blah, if i paint my engine cover by just cleaning it out real well and not sanding anything, will it look alright??
#118
......somebody? i'm so bored right now i wanna go paint it unless i need to get the sandpaper primer and clear coat.... i just painted the battery cover and it looks pretty nice even though i just cleaned it and sprayed 3 coats
#119
#120
