Question on Hose
Old Oct 22, 2010 | 05:41 PM
Me_XMan's Avatar
Question on Hose
2000 Acura 3.2 TL.
I've got oil leaking out from this hose at the shinning metal point.
It goes into camshaft I believe.
Do you know what is it and what does it do?
Thanks.
Old Oct 22, 2010 | 06:16 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Looks like a power steering hose.
Is the fluid comming out of there the same color in the ps fill container ?
If that is the hose you are looking at,they are almost 100 bucks new.
Old Oct 22, 2010 | 07:06 PM
Me_XMan's Avatar
I ran the engine and oil starting to drip from that metal connector.
Yup it's the PS pressure hose.
How hard to replace it?
Old Oct 22, 2010 | 07:37 PM
01tl4tl's Avatar
its just a hose --call NAPA or other auto parts store for a good aftermarket one
dont expect them to have in stock--takes a day to get etc
you will need some new HONDA ps fluid--
do a flush of the system while you are at it...and to burp air from the system
tip: place cardboard under front wheels so turning them back and forth to burp air is easier on the system-less friction on tires to cardboard than road
Old Oct 22, 2010 | 08:06 PM
Me_XMan's Avatar
Thanks for your help.
Old Oct 22, 2010 | 08:11 PM
fsttyms1's Avatar
Yup, thats the high pressure side PS hose.
Old Oct 22, 2010 | 08:12 PM
fsttyms1's Avatar
Oh and its going to be expensive.
53713-S0K-A04 HOSE, POWER STEERING FEED 001 2000 TL 129.62 $97.22
Old Oct 22, 2010 | 10:06 PM
Me_XMan's Avatar
Do I need to replace 0 rings?
I can see one end with 91370-SV4-000 O-RING (14.4X1.9) going into the pump. What about the other end to gear box? Looking at the diagram I can't tell which O rings to get. Any help is much appreciated.
Old Oct 22, 2010 | 10:36 PM
Me_XMan's Avatar
Are these all the parts I should get?
91304-P0H-013 O-RING (7.8X1.9)
91370-SB3-950 O-RING (8.8X1.9)
91370-SP0-003 O-RING (6.8X1.9)
93402-06012-08 BOLT-WASHER (6X12)
95701-06020-08 BOLT, FLANGE (6X20)
95801-06025-08 BOLT, FLANGE (6X25)
Old Oct 23, 2010 | 10:39 AM
01tl4tl's Avatar
contact one of our vendors-see list next to Log Out box-
thats dealers that give a discount,,,tell them whats wrong and get the correct parts with it
they will know what you need
Old Oct 23, 2010 | 10:40 AM
01tl4tl's Avatar
yes on new orings
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
navtool.com
Sep 25, 2015 05:15 PM
