Question on Coilovers
Old Aug 8, 2001 | 02:07 PM
ChinozTL's Avatar
I was looking for a cost effective coilover that will work with the stock shocks. I saw 2 on Tim's site. The Ground control and the Shunk2. Can anyone tell me what the difference is and which one is better.......also if anyone has em and whats the hieght adjustablity on them. Any input would be appreciated. Thank You
Old Aug 8, 2001 | 02:54 PM
[VTEC]TL's Avatar
RWD convert
I'd go with the ground controls. I have them and so do many other TL'ers on this board. They use eibach springs and they utilize a single locking perch which makes adjustments quick and painless. I have my Ground Control's on pretty much the lowest setting and there is no bounce at all, albeit the ride is pretty stiff though.
I say go for it and slam that TL!
Old Aug 8, 2001 | 03:20 PM
ChinozTL's Avatar
Thanks for your input man. Had one more question for you.......how hard is it to adjust the height with thouse and how is it done............do you some kind of tool with it to do it??
Old Aug 8, 2001 | 11:27 PM
[VTEC]TL's Avatar
RWD convert
Adjustments are a piece of cake. First jack up the car. Then you use the provided Allen key to unlock the perch. You then twist it either clockwise or counter-clockwise depending on whether you want to raise or lower the perch. All thats left is tightening the allen screw again to lock the perch and you're done. It's that simple!
Old Aug 9, 2001 | 05:27 PM
ChinozTL's Avatar
Question
Do you need to get one of those caster camber kits if you get the ground controls??
Old Aug 9, 2001 | 09:19 PM
Sniper_mjh's Avatar
where are most people dialing in there TL with ground controls? Also, how much is an alignment. I know you should get one every time you adjust hieght...
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
eastsideride
Oct 15, 2015 04:26 AM
navtool.com
Sep 25, 2015 05:15 PM
4drviper
Sep 23, 2015 07:42 PM
