Question about Tread wear?
I know that dropping the car will cause quicker tread wear for your tires, but how long does everyone can roll before they need to replace their tires? Is there any way to make your tires last longer? It's only the inner part of my tires that wear out quickest! Should I invert the tires to use the other side? Has anyone done this? Does the camber kit help with this?
Any comments or suggestions is appreciated!
Thanks.
Thanks.
Honda+Blue=My garage
If you are wearing only on the inside, a camber kit would straighten the tire so it achieves even wear over the entire surface. You paid for the whole tire, use it.
Ya or make alot of HARD high speed turns ,then the outside edge will wear, then alot of power take-offs to wear down the middle.J/K
just finish the lowering job with an alignment
Originally Posted by 222star
I have about 25km on mine, I too have noticed the center tread wearing very quickly... anything I can do?
If you really mean center as in center of tread on tire then thats from either to much air or if on the front tire it's more than likely from torque
TL-S driver
you have too much air in your tire. it's over inflated.
As for tires wearing faster if you lower your car, that's not true unless you have a camber problem.
your tires shouldnt wear any faster if the car is lowerred unless you have a bad alignment
navtool.com
09-25-2015 05:15 PM
