Question about Rotora Rotors
I just recently installed my Rotora Slotted and EBC Greenstuff.....works great...however it makes this "squeakin" sometimes while braking. Could it be because it needs to break in? tnx
I got the same set up as you have and I notice mine sometimes squeak. But it's once on a while. Another thing I'm noticing is a like a humming or "rubbing" noise when I apply the brakes. Anyone have any idea what that's about.
did you use anti squeel when installing them?
the humming noise is the slots. thats normal with slotted rotors
sumbdy gettin used 2nite!
I get the humming noise when almost stopped but no squeaking, (and I didn't use the anti squeak stuff) you can feel the slots gripping in the pedal if you're light enough at a slow speed. One thing to do hear is a light grunt just before a complete stop...
Loving my 08 TLS!
I replaced my irotors with rotora ones since they have warped after 75k miles. I do notice the humming or rubbing noise from the slotted rotors. I only put like 50 miles, hopefully they will go away after the break in. I don't remember if there was this noise when I installed my irotors years ago.
Originally Posted by Excelerate
The squealing noise does not originate with the rotors. That noise is from the pads. But you will need some anti-squeal lube on the back of the pads and where it touches the calipers too.
Originally Posted by Phesto
^^^^^I'm thinkig of getting Irotor's would you recomend them or should I look at rotoras?
Originally Posted by Blitz
"I would like to know More."
I get this squeal only at certain speeds while braking lightly. I've tried the anti-squeal as well but that doesnt seem to help. After I tried to rebed them in it doesnt seem as loud as it was before. I noticed when I had stock rotors and ebc greenstuff pads I had no squeal. maybe it is just the combination of these two???
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
