question about debadging
I was bored so I thought I'd debadge my tl I had read the diy a few weeks ago but took awhile to actually do it, stupid me I didn't take anything look before I started today, I took the badges off but don't have goo gone or any substance listed in the diy but I used rubbing alcohol on the 'A' my question is, will rubbing alcohol ruin the paint ? It worked really good, I just don't want to continue if it's gonna ruin the paint
i used a heat gun to heat up the badges and then fishing line to floss them out.
with the adhesive, all i had was rubbing alcohol and that worked fine for me. i overloaded my rag with it too and my paint turned out fine...i did wait a few minutes for the trunk to cool first tho since i did use a heat gun
![](http://i526.photobucket.com/albums/cc342/perrysisombath/018eb72b.jpg)
I wouldn't think alcohol would do to much damage to the paint if any. Worse case scenario may dull the clear coat. As for the burn in maybe try a light compound then wax, wet sand with high grit then compound and wax as last resort.
kuckle1 (07-15-2012)
i had the acura letters deeply engraved after i removed em, it looked really bad. had it buffed out and now you cant tell at all. best part was i was body work done to my front end so he said he could buff the trunk for free
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
