Push button start
Old May 7, 2010 | 02:07 PM
  #41
Rockstar21's Avatar
The Dumb One
wtf is so hard about turning a key!?
Old May 7, 2010 | 02:38 PM
  #42
totaledTL's Avatar
Old May 7, 2010 | 05:51 PM
  #43
friesm2000's Avatar
B A N N E D
simple for the steering lock, just remove the ignition cylinder LMFAO, but you won't have a steering lock anymore though (other easy way would be to jam it unlocked)( but you can't really do much as far as that goes, without some modifaction of the ignition cylinder and such (maybe rig up a solenoid or something), cause that steering lock is purely mechanical, think of why it is hard to turn the key, when the wheel is jammed up against the steering lock
Old Aug 31, 2010 | 11:01 PM
  #44
JDM-UA5's Avatar
what can HONDA do for you
Originally Posted by 02TLSfan
Has anyone tried to install an S2000 push start button in their TL? I'd like to put one in, and I can't see why it wouldn't work as long as the key is in the ignition for the transponder to work. I saw this on the RSX forum and was curious.
Well to answer your question yes I just had my friend do the install today and it works great ,basally you start the car like a s2000 turn the key to the ON position than push the button it is pretty cool mod, the lite comes on when the foot brake is push on than I push the button and my car starts up once the foot brake is released the lite goes out the button is deactivate and it is to me a reminder that my foot brake is on.here a pix of the button on my dash I will take a better pix tomorrow
Old Aug 31, 2010 | 11:08 PM
  #45
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
Originally Posted by lopez205tx
ok its an old tread but you can use rfid to be used as the smart key just place it some spot so you can put you key over it and the key has to have a rfid tag & the rfid detects the key it would activate the 1 and 2 stage ( your goanna have to wire up a sircuit so when it hits a signal it activates 1 and 2 ) and wile it hits the 2 stage it sends a signal to the remote start by pass module ( that has one of your key in their) and all you are left over is just pushing the start button.
i will be doing this to my car in the next month or two But i wanna get a hold of the push start like the new tl's have installed.
I know its a little confusing but its just brain storming> but that bluetooth thing would not work.
http://octopart.com/276-032-radioshack-7528618
another addition to this is figuring out a way to unlock your stirring wheel when the rfid reader detects your tag, it hard but ill see if i can get this done
You could use Audrino to make this all work in a heartbeat and around 50$, you just need the programming know-how.
Old Aug 31, 2010 | 11:12 PM
  #46
ecaf005's Avatar
Thumbs up
clean install!
Old Aug 31, 2010 | 11:46 PM
  #47
03tLsNBP's Avatar
MechEng
sick! i want! but i dont want to mess with the wiring myself
would a shop do this?
Old Sep 1, 2010 | 01:38 AM
  #48
JDM-UA5's Avatar
Originally Posted by ecaf005
clean install!
Thaxs and to answer the other question you can the switch cost about 50-60 bucks at the honda stealship
Old Sep 1, 2010 | 01:47 AM
  #49
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Nice install. I wish there was a way to do it without installing the physical key, though. This just makes it harder to start the car.
Old Sep 1, 2010 | 02:04 AM
  #50
02TL4ATL's Avatar
nice clean install, didnt think someone would actually do it.
Old Sep 1, 2010 | 06:50 AM
  #51
JDM-UA5's Avatar
Yea i did it in my 1995 honda accord ,when i did the install it looked factory and in fact i remembed that the service writer said i never saw an accord with a start button btw my friend installed this one didn't do it but thanks
Old Sep 1, 2010 | 12:04 PM
  #52
V_Langs_3.2TL's Avatar
Rice Patrol
not gonna lie, that looks pretty ill.
i don't see the point of pushbuttons especially when the key still needs to be in the ignition (like most cars) but it is awesome none the less.
It'd look much nicer with the ebony interior IMO, much more sportier
Old Sep 1, 2010 | 12:10 PM
  #53
ANC297's Avatar
Bonki' Ehrite!
Looks hot JDM-UA5. Hopefully I see it on the 12th...
But anyways, I'd say to ninja the button in somewhere so nobody would be able to find it, yet its still perfectly accessible from the drivers seat.
Old Sep 1, 2010 | 12:55 PM
  #54
fsttyms1's Avatar
I still see no point of a push button when you have to still insert a key and turn it to the run position. All you are doing is adding one more step to start the car
Old Sep 1, 2010 | 03:29 PM
  #55
ANC297's Avatar
Bonki' Ehrite!
Pretty much...
A buddy of mines ignition switch went in his corolla so he did a whole bunch of wiring, added a switch, a sensor, and a button...
In order for it to start the car, the e-brake must be engaged, the switch must be flipped to the "on" position, and then you push the button to start the car.
The dash piece was drilled out so the button and switch fits perfectly, and it looks like it truly belongs there.
A very cheap and interesting mod if done correctly.
Old Sep 1, 2010 | 04:11 PM
  #56
03tLsNBP's Avatar
MechEng
this mod is about cool factor, not functionality.
for example, why slam your car if all you are gonna have to do from now on is watch for potholes, curbs, etc? cus slamming it makes it look so much better. functional? absolutely not.
i would imagine it would get old quickly but whenever you drive someone else in your car and they see the starter button, itll be worth it.
Old Sep 1, 2010 | 04:23 PM
  #57
fsttyms1's Avatar
I dont find it cool either having to still insert a key, turn it to run then push a button. Having done a mod with a wireless fob and a button = Cool, having to use the stock key in ignition not
Old Sep 1, 2010 | 06:00 PM
  #58
03tLsNBP's Avatar
MechEng
^fair enough. to each his own i guess.
Old Sep 1, 2010 | 10:43 PM
  #59
totaledTL's Avatar
Originally Posted by 03tLsNBP
this mod is about cool factor, not functionality....
^ What he said-
Old Sep 2, 2010 | 01:34 PM
  #60
JDM-UA5's Avatar
Thaxs ANC yea i should be out there on the 12th
Old Sep 3, 2010 | 10:40 PM
  #61
thug lyfe's Avatar
i have a s2000 push start button in my...............s2000. i mean it's cool and def. a special part of the car but it is pointless. i rather be able to just turn the key all the way like in my TL and start it.
rockyboy
Aug 4, 2024 10:35 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
