Programming Keyless Remote
5th Gear
This is how to program our second gen keyless
THE RULE OF FOUR
1. Turn on your ignition until the dash lights light up (do not start your car).
2. Then press any button on the remote 4 TIMES.
3. Turn to off position (do not remove key).
REPEAT 4 TIMES
You can program up to 4 remotes. All remotes must be programmed at the same time. Once the program sequence is started, the old remotes will no longer work.
http://www.acura-tl.com/forums/showt...te+programming
joflewbyu2
10-08-2015 11:16 AM
SinCityTLX
10-07-2015 01:24 PM
