Problem with replacement passenger side mirror
Old Aug 6, 2014 | 07:41 PM
MBP 03's Avatar
I just installed a new passenger side mirror assembly and I ran into an odd problem. I can adjust the new mirror in every direction with the switch, but the final mirror position will not set into memory. If I move the mirror out of position, it will not return to where I set it when I press the memory button. The driver's side mirror works like it always did. Also, when I put the car into reverse, the mirror tilts toward the car instead of tilting toward the ground.
Is there some type of re-learn / reset procedure that I need to do? I didn't see anything in the mirror replacement section of the factory shop manual.
Old Aug 7, 2014 | 10:03 AM
Nicks2001tl's Avatar
Did you buy a new one or one from a salvage yard? Is it possible that it is the unit itself.
Old Aug 7, 2014 | 10:49 AM
MBP 03's Avatar
It's a brand new mirror purchased from Acura a good number of months ago. I didn't have a chance to install it until yesterday.
space_boy
ILX
51
Aug 15, 2017 12:06 PM
mike from annapolis
May 7, 2017 08:21 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
quake97
Aug 30, 2015 07:57 PM
