Press the recirculation button will sound. dadada ....
That’s a interesting way to put it but yeah if you’re are not a do it your selfer then have a mechanic fix it. The re-circ valve motor has a gear in it that the teeth wear off on one side. You could take it apart and flip that gear 180 degrees if you know what you’re doing
The part is outrageously expensive. either get one from a pick a part place (if you've already done this repair) or try this repair:
https://acurazine.com/forums/second-...repair-848488/
What you told me was an air mix control motor
Shouldn't the recirculation control motor be replaced?
There are three types of air mix control motors, mode control motors and recirculation control motors.
oops, yes you are right; it's the recirc motor but i also forgot to mention both of those motors are identical and so the fix applies to both.
Sorry, can't resist. Does it sound like this: https://www.youtube.com/watch?v=lNYcviXK4rg
