Prep b4 painting question
Old Jan 7, 2007 | 11:37 AM
Got_3.2?'s Avatar
hey
didnt know which category to put this in so im posting it here. maybe ill get more input in this category. mods please move this to which ever category this applies to. thanks
my mom has a Landcruiser with that big black metal grill on the front end. its starting to rust so im thinking about repainting it. but my question is what sand paper should i use to remove all the rust and the black paint thats on it now and which sandpaper to prep it before i spraypaint it? i just looked at it and this grill is solid.
thanks in advance.
Old Jan 7, 2007 | 11:58 AM
PenancE's Avatar
use a fine grit, or else ur gonna see all the hair line marks....600+
Old Jan 7, 2007 | 06:05 PM
maxxxboost's Avatar
Need my Daily Fix of AZ
Depending on how much of the rust has eaten away the metal, i'd take off all the rust with 220-400grit prep for primer with 400 grit.. primer the rust and wet sand it with 600-1000grit and paint.
fsttyms1's Avatar
Use what ever grit it takes to get rid of the rust and flaking paint. Id try to start out with something like 220, and if that doesnt do it go heavier. As you work work your way up till you have the surface smooth, then prime and sand (320-400 then) to help fill and remove any last sand scratches. Take your time to make sure every thing is smooth or it will show.
The Machine
Sep 24, 2018 08:27 PM
drone619
Jan 26, 2016 07:09 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
eastcoastguy
Sep 24, 2015 02:07 PM
datadr
Sep 12, 2015 09:12 PM
