Powerslot Rotors
Powerslot Rotors
Yes it's late x-mas eve and I'm on A-zine cos I'm bored and don't have to be anywhere until 1pm tomorrow. Don't know where this belongs, but does anyone have experience with powerslot rotors or powerslot cyro rotors?
2003 TL-S A-SPEC
So since they warped, it would probably be better to get the cyro treated rotors I suppose. Anyone on here running them. Currently I have brembo blanks in the rear, OE on the front and satisfied pro ceramic pads. I'm looking to upgrade the front rotor/pad combo and then do some actual engine and suspension work for the spring. Next year my car will see more mods.
I have the Power Slot slotted rotors and Hawks ceramic pads installed last week. Had them bedded in today. So far the stops seem shorter. Will know in another 150 - 250 miles. Driving them normally until then.
Former Sponsor
https://acurazine.com/forums/sponsored-sales-group-buys-10/rotora-slotted-drilled-slotted-rotors-special-cl-tl-tsx-324531/
Originally Posted by hockeynut
Yes, I bought powerslot front rotors about 1 1/2 yrs ago. I like them and they do not show rust due to their treatemnt (I did not get the cryo) but they have warped. I admit I had several emergency stops from high speeds (a lot of deer in the area) They did not warp as easy or as bad as OEM Honda rotors. I would probably buy again.
Here is a good brake bedding procedure- and reasons why and what you are doing
It takes more than 1 hot session to get them right.
Brakes that warped due to panic stops often have nothing more wrong than pad glaze, and some hardcore brake pad bedding will usually clean the pads and re-establish the transfer layer of material.
Got the squeels coming to a stop- may be poorly bedded pads
http://heeltoeauto.com/httech/YaBB.pl?num=1184261899
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
