power steering whining
Whats up Acurazine.
I'm pretty sure my power steering pump is about to give way soon. It is constantly whining whenever I turn the wheel, little or all the way. I flushed it and filled it, and replaced an O-ring but still sounds the same.
Also don't believe the pump has ever been replaced, but the car is 10 years old. Any tips on how to go about replacing it?
LOL calllllmm dowwwnnn just playin' around. but really, thats what needs to be done. there are no real tips to do it, pull it out, only a few bolts on it, just a bit tight and put the new one in and make sure you torque the belt right but not too much.
2000 acura tl FPR
Whats up Acurazine.
And yes, Cdn_rider is pretty much right, replacing the pump is VERY easy since it's right there on top. Slip the belt off, undo the hoses, undo 3 nuts/bolts, pump is totally free, then swap the pulley over to the new pump and then install is opposite of removal. Remember to burp the system with your new Honda/Acura fluid by turning lock to lock several times.
Lets just hope you won't need a new rack, those are a BITCH to replace.
Was the pump making the noise prior to flushing and replacing the o-ring ? Was Honda PS fluid used to replenish the system ?
Make sure that the air is purged from the system by turning the steering wheel fully locked each way several times. If you still have the noise, check the belt's alignment and tension. Lastly a pressure test of the unit can determine rather the pump is faulty or not. It may have internal damage and require rebuilding or replacement.
victus1 (03-27-2013)
Thanks guys. I do not think there is a leak causing air in the system because there are no bubbles in the pump. Also, my steering is not being affected. My old car's power steering went bad but it was because the steering got incredibly stiff to where I couldn't leave my house. So I had it replaced.
So now I'm thinking if my TL is just making a whining noise......?
And when I flushed it I just put in top name brand from the local auto store.. was that a bad decision??
Thanks. Should I go to the dealership or is it cheaper somewhere online?
2000 acura tl FPR
I haven't found any dealerships that sell fluid online, but I believe amazon works. Not much cheaper than the local dealerships.
Here's a memo about why to use only Honda/Acura fluid
http://my.cardone.com/techdocs/PT%2020-0027.pdf
Genuine Honda Fluid 08206-9002 Power Steering Fluid - 12 oz. : Amazon.com : Automotive
What are the proper steps to do when I replace the fluid?
Oem
You MUST use Honda fluid and I would get my pump from Honda as well. I know, I know it's $$$. You also have to change the tank too. Sounds silly but it made a difference on mine. I've NEVER had good luck with A1-cardone ANYTHING. Just my 2 cents......
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
