Power Locks wont work when cold
Old Mar 7, 2015 | 02:17 PM
kevinf41's Avatar
I have being having problems with my power locks specially during the winter when it gets really cold. Early in the morning when I push the button on my remote none of my door will unlock, i hear the popping sound it makes when i unlock them but somehow it gets stuck and wont fully unlock unless i use the key.
Anybody has had this problem? i cant figure out what it is
i have a 99 TL
Old Mar 9, 2015 | 10:18 AM
01tl4tl's Avatar
the usual suspects are car battery weak, grounds weak, remote battery weak,
more likely: locks dirty and frozen- protect them with Deep Creep or WD sprayed into key part (have rag under to catch runout) and inside each door where the latch assembly is seen- lube everything
Spray silicone lube can be used (on a rag) on the door, hood and truck rubber seals to prevent them from sticking shut - they ice up bad
a little Teflon type spray does wonders!
Old Mar 9, 2015 | 02:06 PM
kevinf41's Avatar
Thanks for the replied, will definitely try WD and lube the assembly and hopefully that will do it.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
acurajj
Sep 19, 2015 03:47 PM
k6biv
Sep 10, 2015 06:37 PM
