Power Folding Mirror Ideas?
Hi,
I wanted to get some opinions on how I should wire my power folding mirrors. I was originally going to use a JDM switch with a fold button, but that would replace the heated mirror button.
Should I just wire it to my handbrake? That way they will auto fold in when I park and pull up the handbrake. Anyone have another car with power folding mirrors that can give some insight?
I go away for a year and this is what you are up to!!!
I would wire it to the door lock mechanism so that when you lock the doors via the Keyfob it would fold in the mirrors and unfold when you unlocked the doors. The only issue is linking it so that locking from the inside won't cause it to fold because you'd then have to always drive with it unlocked obviously.
I assume you are using JDM PFMs?
The OEM ones wouldn't work as converted PFMs, from what I remember with people who have done the same with the 6GA.
Curious to see how you end up setting that up, I don't think I have seen a 2G TL with them.
Yea, I am using the JDM mirrors. I am setting it up so that I retain the defrost, as well as the memory position mirrors.
Forgive my ignorance but don't these cars also auto lock when you go into drive? That would prove an issue
Have you looked into just installing an alternate switch or maybe using the window lock button?
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Thanks for confirming guys.. I'm just ![Crazy](https://acurazine.com/forums/images/smilies/crazy.gif)
I'd suggest the window lock button then
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
