possible headlight problem
Old Mar 13, 2002 | 09:22 AM
fahoumh's Avatar
Shogun Assassin
Last night, when I got out of the car and did a little inspection of the car and saw moisture in a couple of spots in both headlight casings. It was around the bottom of the circle for the highbeam and in the signal lamp area, around the reflector. I wiped the lenses just to make sure that it wasn't scraped plastic and sure enough, it was on the inside. This was the first time I ever noticed it.
Has anyone else had this problem? Should I take it into the dealer?
Old Mar 13, 2002 | 09:31 AM
randomwalk101's Avatar
Re: possible headlight problem
Water condensation should not be in your headlights..if it is, seal is not good/broken. It's a good idea to take it to the dealer for replacement..
Old Mar 13, 2002 | 09:57 AM
Or the lens might have a small crack in it allowing moisture to enter. Have the dealer check it out...
Old Mar 13, 2002 | 10:20 AM
fahoumh's Avatar
Shogun Assassin
I called them...I'm going in later today. Thanks
Old Mar 13, 2002 | 10:38 AM
Bitium's Avatar
Retired MOD
Talking Re: Re: possible headlight problem
A very little amount could happen. It will go away quick. Each headlight has 2 breathers so condensation does not happen, but a little might.
Old Mar 13, 2002 | 03:51 PM
fahoumh's Avatar
Shogun Assassin
Re: Re: Re: possible headlight problem
I took another look today and there was none....perhaps it was a freak thing. Ah well, if it happens again I'll take it in. Thanks again.
Old Mar 13, 2002 | 04:14 PM
Slammed99TL's Avatar
Yeah right when I got my 02's tails I was washing the car and and I noticed a little condensation in the reverse signal part and later on that day it was gone and have not seen it since
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
