Possible fuel pump problem
Old Apr 1, 2014 | 08:27 PM
  #41
CAB NY's Avatar
Tri State ViP Crew
rode around yesterday and the car cut off on me a few times and stutter and each time i banged on the pump in the trunk it would start back up or run normal so i just finish putting a new pump today and the relay was changed Friday i'll see
Old Apr 1, 2014 | 08:52 PM
  #42
ErickUa5's Avatar
Mr.Helpful Diagram
The pump has ground connection in the trunk right by the pump cover, have you inspected that ground point?
Old Apr 1, 2014 | 09:03 PM
  #43
CAB NY's Avatar
Tri State ViP Crew
yeah all good and tight and pump didn't cost much so i put in a new one so if its still running funny at least i know its not the pump or relay
Old Apr 18, 2014 | 09:01 PM
  #44
CAB NY's Avatar
Tri State ViP Crew
So far so good still running fine with the new pump
Old Apr 19, 2014 | 08:19 AM
  #45
3.2TLc's Avatar
Maybe it was the previous aftermarket pump.....or connections ?
Oh well, thanks for following up !!!
Old Apr 25, 2014 | 10:16 PM
  #46
CAB NY's Avatar
Tri State ViP Crew
When the shop changed the first pump they didn't change the screener It was brown, dry and coming apart and it's nothing to change the screener it only cost me 8$ i should have did it myself the first time
Old Jan 2, 2015 | 01:15 PM
  #47
CAB NY's Avatar
Tri State ViP Crew
Back at it again same problem car not starting once again i banged on the fuel pump cover and the car started again and its still under the warranty but I can't find the receipt from last April
Old Jan 2, 2015 | 01:30 PM
  #48
Tosh's Avatar
Eurotrash
A good shop will have your file in their system and honor their warranty.
Old Jan 2, 2015 | 04:42 PM
  #49
TLer trash's Avatar
What brand of fuel pump are you using? Fuel pump failures on any honda are rare. There are aftermarket fuel pump brands that are ok, but some are pure CRAP. I'm not referring to no name, internet stuff, but a recognized brand.
Old Jan 2, 2015 | 05:38 PM
  #50
CAB NY's Avatar
Tri State ViP Crew
I dont remember what brand the pump was but the warranty is six months so time is up they said to change the fuel filter but I was told that there was no filter just the screener but I was told there is one does anyone know thanks
Old Jan 5, 2015 | 05:46 PM
  #51
ErickUa5's Avatar
Mr.Helpful Diagram
Im thinking your fuel pressure regulator might be stuck closed killing the pump. You should have it tested when putting a new pump.
Old Jan 8, 2015 | 12:32 PM
  #52
CAB NY's Avatar
Tri State ViP Crew
I changed the pump and the car is running fine now but i was shown a pic of feul filter that looks like the housing that the pump goes into does anybody know if that is a filter also because one place said the screener is the only filter thanks
Old Jan 8, 2015 | 04:16 PM
  #53
TLer trash's Avatar
The in-tank filter is also called a strainer, screen, or sock. It's the only one on your car. If you don't have a ton of dirt in the tank (usually from a rusted out filler tube), I think you're getting crappy pumps. I took a look at rock auto, and the only ones I would consider are bosch, delphi, or denso.
Old Jan 13, 2015 | 12:42 PM
  #54
CAB NY's Avatar
Tri State ViP Crew
I changed the screener but the part store is showing me this which looks like the housing
1999-2003 Acura TL Fuel Pump Filter - Fuel Delivery - Beck Arnley 99-03 TL Fuel Pump Filter - 5951-05165456 - PartsGeek
Old Jan 13, 2015 | 02:43 PM
  #55
TLer trash's Avatar
I'd call it a housing too, based on that picture.
gator90065
Oct 8, 2015 10:14 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
