Port and Polish with a dremel.
well....there is cleaning the edges to remove casting irregularities and there is specific porting depending on what you are looking for
If you are just bored- clean all the edges so no flow disturbance from that and you will see improvements across the board
i heard it was crap doing it by hand, as in, don't do it and leaving it to the professionals to do it. But i always wanted to do it myself. I guess the gains are made because you open up the ports so that more air goes in.
hahhahh
no~
its angles and airspeeds and direction of air spin and then when in vtec that all changes as it delays the 2nd intake valve opening just a hair, creating its own tornado as it enters the combustion chamber
smoothing rough edges so all the holes match size is good
If you have a spare manifold to play with- try it
otherwise step back sloooowwwwwly from the engine bay.....
and focus more on how aircraft speed polish will make the car faster
wax on
wax off
no~
wax on
![Boogie](https://acurazine.com/forums/images/smilies/boogie.gif)
Originally Posted by 01tl4tl
hahhahh
no~
no~
what are you saying no to? more air plus more fuel = more power. do you agree?
when you port the head, you take away some restrictions to open up the intake and exhaust ports.
slobalt defender
I ported and polished my S manifold when i put it in, i used a dremel with an extension to get all the way in. The main part to focus on is the intake horn, basically the Y shaped part of the manifold. If anyone wants a spare TLP manifold for cheap PM me, i have no use for it.
did you notice any difference when doing this mod? I'm assuming you didn't port match the head huh?
you can do it with a dremel. ive done it. You have to becarefull though, you dont want to try to enlarge things too much, you can cause a negative effect. TYhose who ask if you can feel a difference, No, but when was the last time you felt 5-8 hp??? Do a search, ive posted pics of the one i did.
You would see the largest gains if you port matched the head as well
slobalt defender
no my heads are not ported, but my lower manifold runners are and that helps a bit. Every little bit of increased airflow helps. My throttle body is also bored. I put everything on at once, typeS manifold hand ported, typeS TB bored, and lower runners extra honed. I definately felt gains but by just porting your manifold a bit i doubt you could feel it.
Here is what i did to mine
![](http://img98.exs.cx/img98/51/picture0840lw.jpg)
![](http://img98.exs.cx/img98/8893/picture0929ck.jpg)
![](http://img98.exs.cx/img98/4784/picture0828fl.jpg)
![](http://img98.exs.cx/img98/413/picture0914mx.jpg)
Good pic examples of what I was saying about smoothing the roughness out
What I said NO to was- that simple guess and go for it porting was a viable method= no
Originally Posted by nizmugen
I heard you can pour sand in the motor and achieve the same results.
maybe too much late night tv with the duralube demostration
We poured tar, chicken feathers, sand and cut the coolant lines and this motor ran for several seconds before suffering terminal damage, and 30 minutes before it blew into little pieces of shrapnel !!!
Or perhaps he meant that amatuer porting attempts work about as well as pouring metal shavings in you oil
Originally Posted by burnerjunky
maybe like sand blasting the inside would work.
InFaMouSLink
10-30-2015 09:43 AM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
