pls help its getting late?????
I try to install my body kit right now people say that u only need 4 screws in fornt but when i look at the frotn kit it has 9 holes and two holws on each side now im confuse. HELP pls what screws go in fornt??
Dragging knees in
Yes, drill all the necessary holes. Put the front body kit piece on the car. It'll be better if you have someone else hold it tightly on there for you while you mark the holes.
Grab a marker and follow the holes that are on the body kit piece. Mark them accordingly onto the actual body panel piece. Take off the body kit, and drill. Make sure you use a drill bit smaller than the screws, as to put 'em in tight. It comes with nuts (I think.. I didn't use 'em) that will go on the other side the body panel to hold the screws. But as long as the screws are in the hole tightly, you won't need to use them.
If the front piece takes more than half an hour to do, then you're doing something wrong.
IM me at GrandPrixC if you need any more help.
us285126
10-02-2015 02:03 PM
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
