Pleeeaaaase Help
Old Sep 20, 2009 | 02:04 AM
teggy turned tl's Avatar
Pleeeaaaase Help
Okay i fanally got a chance to fix the heated seat prob. i followed all the directions and now my srs light is on and i also have no controls over the driver seat its, completely dead. Also i checked and rechecked all the plugs and they are all in the right places i checked to see if they were getting power and there was no prob there either so now im stuck and dont know what to do. i guess the car will have to go to acura unless somebody can save the day.
Plleeeeeeeeeeeeeeeasse help
Old Sep 20, 2009 | 02:35 AM
01tl4tl's Avatar
no problem- you unplugged the seat connector stuff- including the airbag power with the battery connected- right?
its just fooled the system
easy fix- check the diy again for the link or search for SRS reset
If I had it handy I would have given- sorry
Old Sep 20, 2009 | 08:55 AM
nsnrider's Avatar
here you go:
http://www.geocities.com/myintegra96/srs.html
very easy to do.
Old Sep 20, 2009 | 07:11 PM
thank u so much now the srs is off but i still have no control over the seats any other ideas of trouble shooting or solving
Old Sep 20, 2009 | 07:47 PM
01tl4tl's Avatar
recheck the seat connectors- any chance 2 look alike?
check fuse box for power seats- maybe popped a fuse with the battery connected
Old Sep 20, 2009 | 09:39 PM
fsttyms1's Avatar
Check fuses, double check that you have ALL the connections plugged in.
Old Sep 20, 2009 | 10:44 PM
celiboom's Avatar
I know exactly what's the problem. I did mine last week and after replugging everything, i had no power in my seat. On the side of your seat, under the plastic cover, there is two out of the 3 connectors that are square. You plug it color match but as stupid as it may seems, you must plug the connector in the opposite color socket?
I don't know if you see what I mean but this is 99% sure your problem!
Old Sep 20, 2009 | 11:02 PM
probmxstyle's Avatar
x2, i had the same issue
Old Sep 21, 2009 | 05:38 AM
im going to try this when i get home from work but when i checked it last time it didnt seem like it would reach if i flippped it around because there is a third plug that is closer to the front part of the seat than the rear
Old Sep 21, 2009 | 07:41 AM
01tl4tl's Avatar
one wiring harness for many countries,,and which side of the car is the driver seat etc
Not everything makes sense when you look at the wire harness~
This is a good reminder for anyone working on electrical in the car-
A: Disconnect the battery NEG cable
B: MARK each side of a connector with tape-write a code number/letter on tape so it goes back together fast and right the first time
C: When things dont work- suspect the last thing done to the car~
Old Sep 21, 2009 | 08:02 AM
totaledTL's Avatar
x3, this was my problem also.
Read through this thread for more info: https://acurazine.com/forums/showthr...ight=connector
If no power check your fuses.
Old Sep 21, 2009 | 10:39 AM
Shafted33's Avatar
3rd Gear
The first thing I always check is the fuse panel. If your solder work caused a short it would pop a fuse and you would have an issue. It could also cause the car to not recognize the side air bag.
Old Sep 21, 2009 | 03:30 PM
you guys are the F ing ish...... i came home opened the side panel sure enough your right there are two blue plugs and one grey the two blue plugs go on the controler and the grey one attaches to the blue socket there was my mix up. i thank you so much u have no idea you saved me 95 dollars at acura and not to mention an awkward trip to acura considering the seat could not be adjusted
Old Sep 21, 2009 | 04:42 PM
celiboom's Avatar
héhé noproblemo!
I had the feeling I had to register to tell you the solution!
Old Sep 21, 2009 | 07:41 PM
goMO's Avatar
good for you!! I have the same problem with the heated seats. I checked the fuse today, but it is fine.. Its the #3 on the passenger side. I was hoping for a quick fix..
