Please correct me if i am wrong
i have to strips of LEDS for my footwells. Can i simply remove the door panels and tap into my courtesy light. i would hook the +to the white wire and -to the black wire and they should be good right? thanks for any help.
It was actually quite easy. I just mounted my LEDs in the footwells. Then took off the door panels. if you look in the door jam towards the front fender you will see a rubber tube that has your doors wiring harness in it. i took the wire i bought to hook the leds up with and ran it through that boot. there is a hole in the door panel about 4 inches from the hole and with a coat hanger and some patience you can weave it through the rubber thing and out that hole.
Now you should have an Led with a red and black wire mounted in your foot well, and then you have your courtesy light in the door with a yellow wire and a white wire. the white wire is your positive and your yellow wire is your negative. with the wire you ran through the door just splice the red wire to the white wire and your black or negative wire to the yellow. open and close the door to test your work. if all is good then pop the panels back on and hide all your wires and enjoy the fruits of your labor
ITSJESTER
17
Dec 6, 2018 02:29 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
guyvelella
Sep 30, 2015 11:02 PM
