Pinned Temp Gauge
Old Apr 5, 2018 | 04:56 PM
AK80's Avatar
Pinned Temp Gauge
2000 TL - 200,000K+.
Just replaced the thermostat. Put the old one in a pot of boiling water and it opened right up. So the “overheating” wasn’t from the t-stat. The temp gauge will literally top out....past the red. But there’s no signs of it actually overheating other than the gauge. Radiator is full. Reservoir has fluid in it. Top hose is hot when I check after driving, but the radiator is cold. I’m thinking water pump, but would be interested in people’s thoughts. When I start the car it immediately goes to the normal operating temp on the gauge....but it should be registering cold. Then in about 5 mins it pins it high.
Old Apr 6, 2018 | 11:16 AM
MBP 03's Avatar
If the engine is truly not overheating, then it sounds like you may have a bad temperature sending unit.
Old Apr 6, 2018 | 12:46 PM
AK80's Avatar
True, but the radiator wouldn’t be cold when it’s warmed up if that was the case would it?
97Acura3.0CL
Dec 21, 2005 11:00 PM
subbuzz
Nov 22, 2005 04:17 AM
