Picked up CL6 Engine/Tranny, amazing price!
#42
Correct sir. Now I plan to have a custom Intake manifold setup in a few months. I figured I could take the top end apart, have the heads milled and leave the gaskets intact. that will increase my overall static compression slightly.
While I'm at it I plan to add the blockguard and upgrade valvetrain. Richie's harness makes for the rev limit to be a little higher. Not sure if gains are to be had with just a stock ECU but I'm sure with tuning...we could finally have some fun.
Also makes for some nice insurance with the upgraded parts.
I am still trying to afford a standalone. I think it will be much less heartache to go with that rather than tooling with the e-manage and FIC.
Now that the tuning is becoming more supportive, I hope you can get a jumpstart on the rebuild. I wish I could turn back and start all over sometimes. It is a nice OEM upgrade but I'm just not happy with the money I've spent on it. Should've waited and got the crank knife-edged/balanced, block hottanked, bore 0.5 over, have the rods shotpeened and etc.
#43
The Dumb One
i still havent looked into the accord MT's yet though, i believe somebody said those will work too?
#44
Thread Police Chief
once i find out which 6 spd will be the best bet, i'll start pricing and putting time into my S 6spd swap. so far the 3gn 6 speeds seem to be easier to find.. although they are pricey, its convinient and newer stuff always makes me feel better.
![Cry](https://acurazine.com/forums/images/smilies/cry.gif)
#48
I got the Shifts
#49
The Dumb One
arent they only useful in bad traction situations... lets say dry road cool day, isnt LSD kinna just sittin there unless theres a reason road conditions are unsatisfactory..
my 944 has LSD and my older accord didnt.. never really new the difference b/c they never acted any different...
#50
Thread Police Chief
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
PM me your number foo! Can you get texts?
#52
Will do. You spoke to Constantine right? Good guy right there. If you want we can rip the car apart together
I called him a couple of days ago and told him I was coming to get the ECU, as well as all the in-dash wiring I can salvage and the pedal assembly. I'm told him I'm going to TRY to pull the master cylinder, but that thing is wedged in there so tight I doubt it will happen...
#58
If you can get back to that car take the IMRC controller out from under the dash (if you havent already)
#60
Thread Police Chief
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/13s3m0_e0320.gif)
there's some control unit inside the dash for this? I just assumed the ECU handled it. Where under the dash it is? Is it part #5? 37850-PGE-A01 CONTROL UNIT, BYPASS VALVE
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/13s3m0_b1310.gif)
#62
Its #5 in the lower diag. Its mounted to the B pillar (just above where the parking brake would be mounted in the auto)
#63
Thread Police Chief
Thanks Kris, I'll be sure to grab it when I go back. I plan on pulling all the electronics and wiring out that I can to be on the safe side, other than the steering column stuff of course. That belongs to Phee
Silvermoon_Knight
10-22-2015 06:25 PM
Barb Jackson
09-15-2015 02:27 PM
