Perma-Cap
Perma-Cap
my buddy has one of these on his focus and i am thinking about getting, they are soo cool, and just think you never have to take the gas cap off again!!
http://www.autogeek.net/permacapgascap.html
what do you guys think?
I didn't know that all gas caps for all cars share the same threading...I say this because it looks like a one-size fits all type application. The only problems I might see possibly happening are:
1. The check engine light might come on due to the fact that if the gas cap is loose, it triggers the sensor. I'm not sure exactly how the sensor works, but if it has to do with pressure, there might be a pressure loss from that new cap because the "flap" might eventually wear out or not be able to hold in the required amount of pressure needed to keep the sensor from going off.
2. There is a greater potential for people to siphon out your gas. Now granted, they could just screw off the old cap, but for those with locking caps, this new setup could pose a problem. I only bring this up because I bought a used car once that came from Kentucky, and the previous owner's said that they had to keep the gas caps locked because people would siphon out gas there...what people won't steal these days...
Buckle Up
Originally posted by Pawel
Hello..... only way to get to gas cap is by lever inside the car..... so all that gas stealing and sugar will not happen unless the fuel door is forsefully open.
BlingBling INSPIRE 32V
I wouldn't recommend.
the springs on those caps do get old and fail.
there are a couple of really old ones at my local autozone.
they've been there so long that the boxes have faded, FROM THE FLOURESCENT LIGHTS.
Sorta off the topic of this particular thread, but that gas cap reminded me of the new Fram oil drain plug product where you can screw an adapter that has a hose attached to it onto the Fram oil plug, therefore eliminating the need to use wrenches or sockets to remove a standard oil plug and also minimizing mess when draining.
Tony
Tony
Originally posted by pianoman41
I saw this too. Certainly seems appealing but I'm guessing it is some kind of ball valve and I'd be nervous if somehow something got stuck in there and started it leaking.
Of course, if you had crud in your motor oil, that in itself might clog the valve itself but then, that would be the least of your concerns...
Tony
