performance mods for 02 tls
I am a newbie to the front wheel drive performance area.
I know that solid and thicker sway bars are the way to go and progressive springs are better than shorter ones.
What works for stiff suspension? front and rear strut bars? or just front? I am use to drifting.
What engine mods really work for the vtec type engines? intake, header, downpipe, by-pass pipe, exhaust h-pipes for dual exhaust, pulleys, cam shaft, cams, fuel pressure regulator?
What brake upgrades (beside the comptech ones) are available? are the brakes upgradeable by switching to the NSX ones? I used 300z calipers (4 piston and 11" rotors) and rotors for my 240sx. I found that performance mods for the 240sx can be taken easily off the 300z. is this the same for acura/honda?
Since your use to drifting a front strut tower bar would be my suggestion...
As far as engine mods... it depends what direction you going..
naturally aspriated or other... for basic bolt on.. intake, headers,
exhaust, cam gears, cam shafts..
Brakes.. brembo has a couple of different choices...depends if
your looking for cross drilled or slotted or slotted/cross drilled...
As far as swapping parts... i use to own a 95' integra GSR... they
don't swap too well with civics... maybe rims... if u own a civic and want an engine swaps wit a integra GSR...
pretty good match.. may need extra engine mount...
Cai Intake, Headers, Exhaust will produce about 30 hp
Pulley and v-afc is still not sure if produce alot of ponys
I will test this out hehe. Need my eyeglass holder to get molded for the v-afc. You can get the coilovers or the springs and adj. shock combo. So much to do with so little money
Mr.T
Mr.T
first off get the headers and aem intakle as far as exhaust goes dont even bother the most hp you will get is 1-2 hp other mod s you can do is a 3.5 litre upgrade like i did but you wull have to drive to davie florida and it will cost you about 5000.00 you will get 315 hp and 260 lb of torque................you can also get a torque converter from level 10........................oh and the s-afc doesnt do **** for our cars either
You did all this and still use the stock transmission?
Re: There needs to be more MODS for TL and CL type S!!!
Originally posted by city001
I thought HONDA is king of MODS???!!!
need more upgrade stuffs for the TYPE Ss
G
G
Originally posted by rockinTLS
Man, I had to read that like three times to figure out what you were saying. Punctuation and capitalization would help.
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
ExcelerateRep
10-14-2015 08:20 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
