People in Canadian TL's
If I remember correctly, Canadian TL's have DRL's. Well, I wanted to know are your DRL's the same as your high beams? And when you turn you headlights on then the High Beams/DRL's turn off automatically correct? Is this how it is setup or can someone care to explain how the headlight system and DRL system works in the factory TL's equipped with them. Thank you.
DRL lights is the equivalent to what you guys call your 'low beams'. The DRL come on when you start the car (aren't required to turn them on manually) and they turn off when you shut down the car. They are not our high beams. DRL share the same bulb as the high beams...the DRL are 50% output of the high beams. Basically, it's like running headlights that just aren't as bright as when you actually turn on your full lighting system. DRL are mandatory on all Canadian cars. Once you turn on your full lighting system, the DRL go off and the outter bulbs/HID headlights lights go on --- DRL and the full lighting system do not run at the same time.. it's either one or the other. DRL do not activate the tailights as does the full lighting system.
I believe NYDesi80 means to ask if the DRLs use the high beam bulbs at a reduced voltage....
...but otherwise I believe Street Spirit did a pretty good job explaining it.
You looking to add DRLs to the TL?
Yep -- I said that in my reply... DRL use the same bulbs as the high beams, but at 50% output... DRL use the bulbs closest to the grill...the inner bulbs.
The only options we have on our light stalk are: OFF, parking lights, and full lighting system (and then pulling the lever for high beams).... no option to turn off the DRL (although technically, the DRL go off when you turn on your full lighting system).
Originally Posted by Dark DJ
i want DRL's! ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Originally Posted by Street Spirit
what's the point? just turn on your low beams when you start the car! ??? i turn on my full lighting system whenever i drive... would save you lots of money to just turn the light stalk
Your low beams are equivalent to our DRL, aren't they? except they don't go on automatically?
J
DarkDJ,
You can probably add it but with the same exact setup in the canadian models will be hard. I've looked at the wiring diagram and it looks a lot more complicated. I am sure there is a more simple work around.
Originally Posted by jean
Umm.. correct me if I'm wrong.. but our low beam HID are the same as their low beam HID...
J
J
the only HIDs on stock cars are the headlights for the full lighting system/outter bulbs.. the DRLs/high beams are halogen (stock)... very, very yellow!
Basically I was wondering if you could just add a relay that would turn your High Beams on when the your Low Beams were in the off position and wire it in with a resistor to supply it low current so this way the bulb doesnt burn as bright. This can't be done?
Im sure all the wires are pretty much right by the drivers side fuse panel where we did the fog mod.
And to the person who made the comment about turning on your Low Beam HID's all the time, why would you do that, ur just going to burn out your HID bubls fasters. And HID bulbs are expensive to replace. Buying a relay and a resistor will only cost you like 15 bux and if your halogen bulbs go, they are real cheap to replace. Get what Im saying.
It doesnt appear to be as simple as a relay. The DRL module probably would cost a nice chunk of change and there seems to be a lot more wiring. I am sure that it can be added the right way but there has to be a easier way as well.
Flyin' and Drivin'
I have DRLs on my car, cause I bought mine in Canada and brought it down to Atlanta. I love them, and have seen so many other TLers look at me weird, and 4 have asked me "How I did that." I would like to add a switch in somewhere so I can cut the DRL's off... meaning just splicing a wire and adding a switch. The wiring diagram is pretty complicated, I looked at the Electrical Manual at Acura Carland last week.
Comet2404,
So you just want to add a switch to disable DRLs? Try this... push the parking brake down a little until it is disabled and not enough to actually engage the parking breaks.
I've read that it works in most cars but I am not sure specifically for the TL though. If not there are other solutions and I can probably help you find a spot to do it at.
Let me know if that works.
TLS RULZ
To U.S. TLers...
I'm getting a bit confused here... are you guys not able to use the inner lights closest to the grill for anything other than total high beams?? ...The lights/bulbs closest to the grill are never used except for high beams (switched on manually by pulling the light stalk) on really dark roads? So your only options are the outter bulbs/HIDs for nighttime, no lights at all, or high beams?? You don't have anything option that's even like our DRLs even if you have to turn them on manually?? Just trying to see if I am understanding this correctly...
To U.S. TLers...
why would you want to waste time and potentially money on trying to get drls...i dont see whats so grat about them...i mean if epople dont see you during the day without your headlights on..i dont see how having them on is gonna help...making drls is not as easy as you envison it....to get your highbeams to come on when you turn on the car and turn off when you tiurn on your low beams...your gonna have to be running 2 relays...power would probalby have to come from the acc power since you wnat it to come on th the car...and then you need to run a wire from the low beamas to close the switch when its on...also another relay has to be used to keep your taillights off...no idea if a rlay would even help you there...also even if you had your highbeams as drls...they'd still be running at fulll power and they'd be annoying....
6G TLX-S
Even with the reduced power output, the DRL is still too bright for other drivers, especially during cloudy days and near-dusk and near-dawn conditions. The high beam light is not blinding but still very irritating to oncoming drivers and to drivers driving in front.
MrHeeltoe
20
02-23-2023 01:54 PM
ITSJESTER
17
12-06-2018 02:29 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
