PCV valve
Old 12-16-2003, 01:09 PM
nick79's Avatar
PCV valve
where is my PCV valve located and how do i change it?
i have 54,000 miles and i thought i should change it since i never did before.
thanks
Old 12-16-2003, 01:34 PM
Severin's Avatar
Every PCV valve I've ever seen contains just a spring and metal stopper; simply spraying the inside with "gumout" or any other carb cleaner will do the trick. The worst that can happen is the valve gets gummy with oil crud and doesn't open/close properly.
I haven't looked for it of the TL, but it's usually on the rocker arm cover.
Old 12-16-2003, 01:55 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
i would just replace it they usually arent that much and a can of carb cleaner usually costs just as much and wont make it just like new. and its a the VALVE cover not rockerarm cover
Old 12-16-2003, 02:23 PM
nick79's Avatar
where is it located?
Mike734
12-10-2021 01:25 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
prbori
09-27-2015 01:37 AM
MilanoRedDashR
09-24-2015 11:04 PM
Quick Reply: PCV valve
