Passenger Multiplex Control Unit????
Old Jun 4, 2008 | 12:47 PM
TonyaB72's Avatar
4th Gear
Cool Passenger Multiplex Control Unit????
I have a 1999 Acura TL, I am trying toI guess reset the keyless entry, and I can not find the passenger multiplex control unit, can anyone help.I bought the car used and the clicker was in it but did not work and also wanting to know if the battery in it is 2025..Thanks in advance
Old Jun 4, 2008 | 12:49 PM
phee's Avatar
I got the Shifts
Hey Tonya, the multiplex is the fuse box ont he side of the car, one on the passengers side and one on the drivers side under the dashboard next to the doors.
Old Jun 4, 2008 | 12:51 PM
TonyaB72's Avatar
4th Gear
Thanks Phee, I thot so, was not sure I need help doing this, the instructions do not work ..erk
Old Jun 4, 2008 | 12:56 PM
TonyaB72's Avatar
4th Gear
Question
Should I open the box to program the clicker? or should it ready it like it is?
Old Jun 4, 2008 | 09:47 PM
phee's Avatar
I got the Shifts
ah, you just need a battery lol. just pop open the keyfob (clicker) with a small flathead screw driver and replace the battery. i misunderstood what you were trying to do
Old Jun 4, 2008 | 10:10 PM
TonyaB72's Avatar
4th Gear
The battery was 2nd question on what type is it 2025, and I still can not get remote to work? Thanks
Old Jun 4, 2008 | 11:04 PM
6MTUA5's Avatar
No He Can't
You have to do some specific sequence to reprogram your remote. You stick the key in the ignition and you have to like hold the button down on the remote and turn the key to on or something like that. The guy at the dealer came out there and did it for me when I had to reprogram mine when I got a new one. Hopefully someone can chime in on what the procedure actually is.
Old Jun 4, 2008 | 11:19 PM
phee's Avatar
I got the Shifts
kris knows it. do a search for program keyfob and program remote. i think its something like turning the iggy on and off like 10 times. you may also want to press every button on the remote to make sure its re-enebaled from sleep mode (not sure if it does this) . check the fuses as well
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
Aug 15, 2019 12:58 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Sep 17, 2015 09:01 PM
