parking brake adjustment
Old Aug 11, 2003 | 06:20 PM
Eskimo's Avatar
Question parking brake adjustment
My parking brake doesn't work as well as it used to. The cables must have stretched a bit over the years. Anyone know how to adjust the parking brakes? Graphical instructions would be greatly appreciated.
Old Aug 11, 2003 | 06:49 PM
RACINGHART03's Avatar
There are two types of adjustment. If its minor just look up by the e brake pedal. You will see a nut on a threaded rod tighten it a little but not much or the brakes will drag. If it needs more adjustment than that can give you you will need to pull the rear wheels off. You will see and acces plug on the rotor. Pop out the rubber and turn the rotor around tll the access hole is on the bottom. Reach in there with a flat blade screwdriver and crank in the adjustment gear untill there is there is just a little drag. Then go back up to the front and back off that adjustment just a hair but make sure you adj BOTH rears first. Hope it helps!
Old Aug 11, 2003 | 10:01 PM
mentl's Avatar
What's the trick to adjusting that gear? The spring runs right across it and I had a hell of a time getting it to turn.
Old Aug 13, 2003 | 08:21 PM
Gotta work around it. Its kinda a pain in the azz. It really needs that much adjustment? I usually get them adjusted enuff right at the pedal.
Old Aug 18, 2003 | 09:52 PM
bigman's Avatar
'Big Daddy Diggler'
If the e brake is not adjusted right will this cause my brakes to squeal or "woosh"
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
stalloutboy
Apr 25, 2016 10:28 PM
jliu6789
Sep 8, 2015 08:02 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
