Painting calipers w/ G2 paint soon...
Problem is, I only have 1 pair of jackstands. I'm thinking about painting the calipers 2 wheels at a time...So long as I don't touch the calipers, it should be safe to put the wheels back on right after I paint right?
O.G.
I also used G2 to paint my calipers. Here is a hint:
- try to get 2 jackstands
- jack the same side up for the front and rear
- remove wheels
- brush the paint on the front caliper
- let the front dry and paint the rear caliper
- by the time you are done with the rear caliper, the front should be dry
- then go back and re-paint the front again
- and repeat 3x and do the same for the other side.
BTW, when you mix the paint, I think you only have 6 hours to finish everything before it is no longer good to use. So time everything out accordingly. I got mine done in ~4 hours with 3 layers of paint. The finish product:
Front:
Rear:
- remove wheels
Front:
Rear:
I basically did the same steps as blackshadow but I jacked front set then rear set.
i alternated coats, front left, front right, front left front right... etc... for 3 coats then i went onto the rears.
I used a small can from Duplicolor, $20 from the autostore and it did 8 calipers (2 cars) and there is still some left... 3 coats each caliper. A couple of people told me to drive it a little to heat it up so it will cure faster.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
