Painted Y pipe
Old Apr 9, 2002 | 04:48 PM
NighthawkBlack's Avatar
Painted Y pipe
I just preped and painted my Y pipe with aluminum high temp paint. Will post pics soon. I was wondering since many here did so, how far up the pie did you paint and how much of the ends where it meets the muffflers?
Old Apr 9, 2002 | 05:29 PM
VeiLsTyleZ's Avatar
i just painted up to behind where the Y pipe starts.
no need to really paint the whole pipe.
Old Apr 9, 2002 | 05:32 PM
JD7's Avatar
JD7
Rizzie's the color!
What kind of stuff do you use to prep the aluminum?
rock's Avatar
I also just painted to where the Y pipe starts. Just wanted to paint the area that you can see from behind. I was also too lazy to jack up the car to paint anything further
Old Apr 9, 2002 | 05:35 PM
rock's Avatar
Do you mean if you need to spray some sort of primer or sand the area? I just sprayed the paint on. My Y pipe area was not very dirty. So far no peeling.
Old Apr 9, 2002 | 05:39 PM
JD7's Avatar
JD7
Rizzie's the color!
Ya somthing like that, just wondering if you have to put a primer for metals? or sand?
Old Apr 9, 2002 | 06:32 PM
dimsumo's Avatar
all the way
Old Apr 9, 2002 | 07:23 PM
I just sanded down the pipe and used a couple of coats of high temp black grill paint. I don't think the paint had any problem sticking to the pipe, as it is still all there
Old Apr 10, 2002 | 12:24 AM
will engine enamel work?
Old Apr 10, 2002 | 12:53 AM
Yeah. I used High temp paint with ceramic. Just read and make sure it handles high temp. The exhaust never gets as hot as the engine so it won't be a problem. Just pic a day that is not windy and not humid. Let it dry normal for several hours or a day. Then use the car for a while to let the paint cure at a high temp.
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
