Paint Chip
if the area is small then you have good chance of recovering
1) put your car under the sun for a while under the metal heats up (to help soften the touch up paint)
2) put the paint under the sun for a while as well to heat it up
3) when both are heated up, you will notice that the touch up paint are "more" liquidfied, that's for better result.
4) dont' use the included brush, that thing is ridiculous. use the finest brush or toothpick you could fine
5) get a drop of paint, but it on the chip area and let it spread. it should do that coz' everything is heated up. let it dry (no need to fill out the area yet, do it one layer by one layer
6) when it's dried, put another drop, etc.... under the whole area is filled up and at the same level as the real paint.
7) put on a clear cost on top
Re: Paint Chip
Originally posted by BakedWafer
Got 3 paint chips, using Acura Touch Up Paint. Any tricks?
d
some good reading for you
http://www.autopia-carcare.com/painchiprep.html
Jul 16, 2017 07:33 AM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
Aug 16, 2016 02:49 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
