P0730 code
P0730 code
Just got a scan code of p0730. Problem is Automatic Transmission is missing 4th gear. 1st, 2nd and 3rd are fine shifts nice but once it reaches 4th just revs. I had to use sport shift to get to 5th on the highway.
Changed the ATF and filter recently and overfilled a little over the top mark but other wise can`t think of any DIY fixes.
Rear motor mount is faulty but??
If the shift control solenoids looked clean, try checking the clutch pressure control solenoids as a last resort.
The hydraulic clutch pressure may need measured. Reset the PCM and see what happens.
Also, did ya use Honda DW1 fluid with the drain & fill ? Usually a bit more than 3 Qts. will refill at change.
Recheck the fluid level after driving it briskly up to operating temp, then check on a level surface with the car turned off.
Could it be that the 4th gear pressure switch is dead/malfunctioning irrespective of cleaning? There was a thread on these 3rd and 4th pressure switches a couple of years ago.
Another thing to check out is the solenoid screens....they may need cleaning.
And if you do a drain with DW-1, also replace that black cylindrical filter on top of the tranny right under the air intake.
I did a drain and fill about 6 weeks ago(dw-1) and replaced the filter also.
Also pulled some tranny fluid out it seems I overfilled the oil a little oved the top mark. Smelled and looked fine.
Solenoids are the cars trannys last hope.
Jamus22
06-11-2023 10:08 AM
