Overheating on friend's 2003 TLS
Old 08-15-2012, 04:09 PM
Black TL's Avatar
Hey guys,
My friend has a 2003 TLS with 175k on the clock. Last week he said the car started overheating while he was in traffic (needle at 75% between C and H).
I asked him to check if the fan came on based on previous comments on the site. He will get back to me on this today. I was also thinking of replacing the thermostat to start with given it's the cheapest item that could cause the problem. The car has plenty of antifreeze in it and there are no leaks. What else should we be checking?
Old 08-15-2012, 04:12 PM
Black TL's Avatar
Oh one more thing. How do you check for a clogged radiator?
Old 08-15-2012, 05:10 PM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
If the car has always been on A/F then its almost impossible that the radiator is clogged...
Most likely a Bad Sensor and/or Fan Temp Switch... If not the most expensive Item that can cause Overheating is the Water Pump getting seized.
Old 08-15-2012, 07:51 PM
Black TL's Avatar
Does a water pump make noise if its bad? How do i check this?
Old 08-15-2012, 10:26 PM
Skirmich's Avatar
There is no Easy test with our Timing Belt Driven Water Pump.
With other cars you could check by hand the Pump Shaft but in our cars is very difficult to do it that way.
Honda techs have a Pressure Tool that they attach into the radiator cap to test it, But most of us Doesnt have it. So the easy way is to go to a honda dealer and have that Done IF everything else fails..
Old 08-16-2012, 09:51 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
water pump has a weep hole that leaks coolant when its shaft seal blows
look up from under car for whitish trace line
the additives in old coolant go acidic after 5 years MAX--
radiators are aluminum
thats how they get crudded up and dont flow!!
a non contact heat guage pointed at spots on rad can tell if flow is happening or not
feel the hoses,,top hot as it exits engine and enters rad
bottem hose medium
Old 08-16-2012, 12:45 PM
RC99TL's Avatar
I had the same issue just recently. I have just over 200k and when the car was in traffic with the A/C on the temp would rise. The fan was turning but checked closely it was turning much slower than the radiator fan next to it. Replaced the fan motor (like $125 -Yikes!) and now all is good. I took apart the old motor and the stator brushes were worn down to the wires! and the inside was FILLED with the remaining dust. With the Auto temp the A/C runs often as does the fan, so after almost 14 years and 200 thou is guess it's understandable.
01tl4tl (08-17-2012)
Old 08-16-2012, 02:54 PM
acutee's Avatar
Spin the fans by hand and see if they are turning freely. sounds like fans are not running properly. You got everything as suggested from Thermo, Temp sensor, Fan motor.
Old 08-17-2012, 09:47 AM
01tl4tl's Avatar
aftermarket fan motors are fine to use and less $$
Old 08-20-2012, 06:08 PM
14thandeuclid's Avatar
Fan temp sensor .. or theres another sensor too. Can't remember the name of it (not air idle controller .. but start with those. It's unlikely the fan is gone, and is prob more costly then buying a 40 dollar switch and trial/error if you can't test the current on it.
Old 08-20-2012, 06:56 PM
Black TL's Avatar
We tried getting the thermostat out put couldnt figure out how to get that bottom screw out. Does anyone know of an easy way pls?
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
Pham Alvan
03-16-2016 09:17 AM
UA7_Ando
09-29-2015 01:00 PM
Quick Reply: Overheating on friend's 2003 TLS
