omg what did i do...
Old 01-14-2010, 04:09 PM
  #81
ryk
ryk's Avatar
Originally Posted by slushhyyy
technically it wont hurt the trunk or bumper since they are inanimate objects.....
rofl!
Old 01-14-2010, 04:15 PM
  #82
kyamcg's Avatar
This has to be just about the funniest thread I've read on here.
Originally Posted by jjashaa
get somebody to rear end your car...
^ I think jjashaa is onto something... Drive around until you find somebody that is talking on the phone and driving pretty close behind you. One good slam on the brakes and they'll be owning you a new rear end!
Old 01-14-2010, 04:29 PM
  #83
B A N N E D
friesm2000's Avatar
3 pages of posts within 24 hours
Old 01-14-2010, 05:23 PM
  #84
Keep It Simple in
SLushhYYY's Avatar
fayle
Old 01-14-2010, 05:56 PM
  #85
taintedplay's Avatar
alright guys, its obvious i failed. now, any constructive ideas? if none in a day or so ill cut into my box and go that route
Old 01-14-2010, 05:58 PM
  #86
Avant Garde Wheels
jjashaa's Avatar
do that.
making another box costs less in the long run.
Old 01-14-2010, 06:00 PM
  #87
HOPEFULLY i can just cut the back panel, reach through the port and do it. fixing a back panel would take 2 minutes.
Old 01-14-2010, 07:00 PM
  #88
rockstar143's Avatar
Received 20,014 Likes on 14,518 Posts
So then go for it...
Didn't like the cutting out the trunk floor idea?
Old 01-14-2010, 07:16 PM
  #89
Ok. In the interest of actually helping you. I took some quick pics. I think the bottom piece is your best bet. It's held by 2 10MM bolts. They have plastic covers that pry down from the top. I have an 04 TL btw...but I'm fairly confident they didn't change the design of this. I think if you can get to this...you can loosen the bolts and remove them and then at worst, you'll be dealing with a broken plastic surround. That plastic pice that the bolts are hidden by is one big piece. But if you remove the bolts and yank up hard, I bet you can break it free.
Good luck, brother.
-Jeremy
Just for reference...the top...and it just dawned on me that this might be in the way of removing the bolts when the trunk is closed.
Old 01-14-2010, 07:34 PM
  #90
cant come from the bottom. mdf floor haha that everything mounted too. and ill try that in the morning
Old 01-14-2010, 08:14 PM
  #91
B A N N E D
friesm2000's Avatar
then might help some, but it's not very large though
Old 01-14-2010, 08:42 PM
  #92
Np.
Old 01-14-2010, 09:23 PM
  #93
javery's Avatar
Wow!
If it were me I would rent a pipe camera from your local rotor-rooter or plumbing supply! They also have those snake deals that can grab jewelry and other important items when they go down the pipe. You might get lucky and grab the latch release.
And if your really in trouble ask them about using a pipe bursting torpedo!
Old 01-14-2010, 11:14 PM
  #94
3.2TL
ThreePointTwoTeeEl's Avatar
I don't think I heard anybody suggest this but, go to a body shop. They might have some tricks of their own for cars that are damaged. Ask for help or if you have to, pay a little bit for them to open it. It should cost less than getting a new trunk or replacing your solid gold subwoofer box.
Old 01-14-2010, 11:27 PM
  #95
B A N N E D
friesm2000's Avatar
but most of the trunks they be opening would already be damaged though, so a pry bar is usable, but yeah they may have some tricks though
Old 01-15-2010, 09:04 AM
  #96
rcb2000's Avatar
Originally Posted by friesm2000
cause those bolts mount from the inside of the trunk just like the latch itself :shakehead
not too hard to get to from the pass through in the back seat or removing the seat completely and then going over or around the Sub-box, Guess you didn't read where he has all ready removed or is going to remove the seat to get access to the inside of the trunk.....
Old 01-15-2010, 09:31 AM
  #97
tpick23's Avatar
Can you reach the the trunk lid hinges? Maybe disconnect them on both (or one) side then lift the lid at the edge where the rear window comes down???
Good Luck, otherwise a used trunk lid will run around $400.
Try www.car-part.com to search for one. i used it to get a rear spoiler, OEM used for $85. Worked perfect and even matches the car.
Old 01-15-2010, 03:38 PM
  #98
B A N N E D
friesm2000's Avatar
YES I HAVE , and FYI, his sub box is in the way, which is why he is in this predictament (sp?)
Old 01-15-2010, 06:02 PM
  #99
ok i cut the box, crawled through and got it open. managed to salved 80% of the box. got the acutator working fine. the only thing now is, if i hit the button on the inside of the door nothing happens (i put the steel cable back where it was but theres not really any tension)
Old 01-15-2010, 06:07 PM
  #100
B A N N E D
friesm2000's Avatar
ummm... is the solenoid electrically hooked up, if so, does the key fob work then and if so, did you make sure the switch inside the glovebox is turned on to allow the trunk to work, if not and the solenoid has been hooked up the whole time, that be F***ing hilarious
Old 01-15-2010, 06:12 PM
  #101
ok the solenoid is now hooked up and key fob works. it was the part i disconnected. ill check the switch in the glove box, my friend was messing with that and i didnt think to make sure its on
Old 01-15-2010, 06:16 PM
  #102
B A N N E D
friesm2000's Avatar
so the solenoid had been disconnected too along with the cable too(just making doable sure)
Old 01-15-2010, 06:20 PM
  #103
right. the solenoid and cable both were disconnected. which stopped me from using the keyfob or door button. now both are back on, and the keyfob works, but the door button doesn't. ill check the button in the glovebox though
Old 01-15-2010, 06:25 PM
  #104
B A N N E D
friesm2000's Avatar
that would have been funny though if the solenoid had still been connected, and you could have had just pushed the keyfob
but yeah if the keyfob is working, then i would say for the door switch there is a very high chance that the glove box switch is just turned off then, cause the body control module/multiplexing unit can control the trunk, when you push the keyfob
  #105
So you're in the trunk then? Meaning, you were able to use the FOB to open it?
Old 01-15-2010, 06:29 PM
  #106
B A N N E D
friesm2000's Avatar
he got in by going cutting up the sub box
Old 01-15-2010, 08:21 PM
  #107
but in doing so was he able to put back together what he needed to to get it to pop?
Old 01-15-2010, 10:00 PM
  #108
B A N N E D
friesm2000's Avatar
yes, but he lost his sub box in the mean time (by having to cut it up)
Old 01-16-2010, 12:34 AM
  #109
I Drive Like A Dick 8≈
Nersh7's Avatar
BHAHAHAHAAHHAHAHA way to funny man, sorry for your bad luck
and glad to hear you managed to open it without cutting the trunk
DDT-TypeS
09-27-2003 07:05 AM
Quick Reply: omg what did i do...
