OMG......I love my CAI.
I can't believe the difference. I have always felt 1st gear was sluggish, but now I can feel the engine is breathing better and is so much more smoother. It was a pain to install, though with my 99. I had to bypass the mini-radiator in the filter box and relocate the cheesy alarm horn. I put it on half way Thursday (short ram) first, then completed the installation Friday.
The car is so quiet when driving normally, but what a sleeper. The sound is so gratifying. Now when I dust someone, they can use their hearing senses as well as their seeing.
Under Body Kit/Rear Wing Spoiler/26 Piece Wood Grain Console/BurlWood Shift Knob/30% Smoke Tint/Comptech Sways & Springs/02 Tails/Clear AEM CAI/Altstadt I's (TBI Wednesday)
More Pics
Moderator Acura-TL.com Tires/Wheels Forum
More Pics
WayTooManyAcuras
WOW! Looks great, excellent pictures!
Does it make the car louder when you are just "normal" driving, or only when you tromp on it??
Congrats!
:-jon
2002 TL-S NAV Black/Black
w/Spoiler, Body Kit, Bowling Ball Wheel,
Bowling Ball Interior Trim Kit
Comptech Springs
Comptech Exhaust
StreetEffectz Audio Upgrade (Coming Soon)
Pictures at:
<A HREF="http://albums.photopoint.com/j/AlbumList?u=1626677&f=0
" TARGET=_blank>http://albums.photopoint.com/j/AlbumList?u=1626677&f=0
</A>
Congrats!
:-jon
Comptech Springs
Comptech Exhaust
Pictures at:
</A>
Adam,
Does the bottom section have a bracket to hold it steady? I have one of the earlier ones made for the Accord, no bottom bracket and I just noticed today that it has worn a hole clear through the back of the lower section. I'll have to convert to short ram tommorow and order a new intake.
actually just to give guys a lil info the newer cais, it comes with that extended metal piece on pipe that goes into the bumper what did you guys do to it?
i placed a rubber plug from the resonator box(the big black box the rubber piece looks just like the one that aem sent but without screws on it)
use that to mount behind the headlight, theres a couple of holes there just use one of them...
Looks good Adam.
Tom
2001 Nighthawk Black Pearl TL
Comptech springs,Xephyr,Performance CAI, Inspire tailights,Piaa super white 001 solitare fogs, Inspire fog switch,Burlwood shift knob,Piaa Xtreme white blinkers,Razo carbon fiber pedals,BEL 870 radar detector, Acura-TL.com sticker
Tom
nice!
make sure the lower section isnt rubbing any metal
test your alarm horn, it wont work. you know that bracket that was under it? you NEED in place to make the horn sound properly. just put it under the horn
Actually, the alarm horn works fine. Still beeps.
The new CAI's mount to a hole behind the head light. The instructions even say there could be a wire loom on some models, which includes the TL, so just remove it and use that hole. They supply you with a rubber bushing with threaded bolts on each side. I just put it through, tightened it underneath and then attached the bracket to the top.
Looks nice Adam. Did you use the factory touch up paint on the battery cover and the valve cover?
2000 TL Pearl White w\o nav
1991 Volvo 940 Turbo Taded
"Just Shut Up and Enjoy the Ride"
Originally posted by Nate:
Lookin nice! Wheres the rims!?
BTW, I gotta paint my engine and battery covers silver now!
BlackTL2k:
I was thinking of red before, but after I painted the components to match my car, I saw the red CAI is anodized and wouldn't match. So I flipped the color scheme.
how/where did you mount the lower part of the cai? did you have to cut it? I have my aem plus bypass installed just like yours in the picture but can't find a place to mount the lower half. AEM tech said the correct way is to cut the upper pipe and install the bypass valve there.
There is a hole holding a wire loom right behind the head light. Remove the loom and use that hole. The instructions mention it too. I put the valve between the two pipes, like other members, but you may have to bend the arm on the lower pipe slightly to get it to the hole.
Cutting is the best way but not necessary in our car.
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
