okay need some help with lights
I have dead hookers in
since i cant drive the car i installed some LEDS in my footwells. i just tapped into the courtesy light fuse on the passengers side. the problem is they do not turn off. I grounded it on a little screw in the fuse panel. what do i need to do to fix this. i tried searching but found nothing
S E L L
Tap the ground from your lights into the ground wire in the door jamb switch. The switch connects and disconnects the ground to turn the lights on and off.
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
