Oil Problem
No Oil spots...no leaks no power loss no temp rise or oil light...I am taking it in but I can not figure out what the problem is. I hope using the synthetic oil protected me . I think if it was summer I would be crying now. How would I know if I did any damage. I mean what it the light for ..I know oil pressure but how much oil would you have to be down for it to come on? ..
well if you are burning it nothing you use will protect you any more. did you for get to add the missing 2 qts? if you arent leaking and you didnt forget to add enough then youare burning it, and 2 qts in a week is really BAD
the only time that happened to me was on my 95 accord...i cleaned out all the oil with the machine at the oil change place.....and after a lil while all the oil goes in the engine and u have to fill it back up
Did it do damage
I was hoping because I used the good stuff I would be ok..I mean if I used regular oil and it was summer I would be all done but mobile 1 in the cold weather ..the oil pressure light never came on ..around corner or hills... what use is that light?
normal white smoke .. I have heard of being down oil 1or 2 quarts and no damage. I hope because I had the synthetic oil film protected me. The commercials for oil drain it all out and run them.//so I figure I am ok.. ya think
Jack up the car and look by the oil pan. Check for leaks.
It's highly doubtful that the car could go from not burning oil to burning 2 quarts of oil in a week. It has to be a leak somewhere. Have it checked out.
mada51589
Jan 9, 2025 04:40 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
