Oil Leak Updte. Plz read
I have an 03 type s and it has now hit 600 miles. My mom mostly drives the car but she has a light foot and usually accelerates slow and only really gets the engine up to around 2200 rpm's when she accelerates. After she drove the car for the week the car wasnt leaking oil. Now I drove the car and be it I go faster I didnt push this car cause its new and I only did up to at max 4300 rpms but when I parked the car and about any hour later it was leaking oil again!! Also the tranny when i shift from park to drive and stuff I can hear it shifting? Is that normal. Gonna take the car to the dealer tommorrow and tell them about the tranny and oil leak.
Hearing the tranny shift from park to drive is normal. However, you should not have an oil leak. Is the oil brown or red color. Red=transmission fluid. Brown=engine oil. Hopefully it may be just a loose oil filter, but get to the dealer ASAP. Even if it is the oil filter, and it comes off, you will lose all your oil. Good luck.
Originally posted by ecko123185
Its brown oil. But if it is a loose oil filter then how come when my mom drove the car it didnt leak oil?
Thnx for telling me. Cant jack up the car right now. bout to sleep cause I gotta take the car to Acura tomorrow to get a hole in my seat repaired but I will tell them to check it. Thnx for helping yo.
Originally posted by ROCK
If it is not tight enough, the vibration from the engine could slowly loosen it more, causing a leak later on. Can you jack up the car to check where the leak is? Hopefully it is nothing serious
OOO no same thing happened to me. Cracked block casting. Crawl under the car and look around to find out wheel all the oil is going. The crack was right on the VTEC oil supply boss so that explains the oil lose only at higher rpm's. Look on the back bank of cylinders near the oil filter. Look for a line of oil running down the block. Hope this isn't your problem. :wow:
took it to the dealer and they were like it was a messed up rubber seal thing? So they replaced it w/ a new seal. Looks like its working cause car aint dripped today and I drove it kind of hard. Well see what it does over the next week or so.
mada51589
05-03-2022 08:54 PM
IIDXholic
10-08-2015 07:53 AM
winkyyy
09-11-2015 04:40 PM
