Oil Change questions
1. The manual asks 5w20, but here I only see 5w30 sythetic, is that ok for our TL?
2. I have 4000 miles ( most are local miles)on my TL, and the oil in it is still the "factory break-in" oil. So should I change it out cox of the 4000 miles, or I should let the "break-in" oil sit in there longer?
Thanks.
Thanks.
Originally posted by OU Sig
5w30 is just fine, actually thats what most people use. You can go at least 7000 miles on synthetic - maybe a little less on regular.
DC Cruiser
I replaced my factory oil at 7.500 w/ Mobil 1 5w30. I then changed my oil at 15K. I now change my oil and rotate my tires at the same time every 5,000 miles, easy to remember. Also, most of my miles are rough city miles, so there is a bit more "wear and tear" than normal.
Costco sells 6 quarts (1case) for under $24. I heard someone talking about a full oil change w/ Mobil 1 at Walmart for $35 which is hard to believe, but will check out soon cuz that sounds like a good deal!!
i change my mobil 1 synthetic 5w30 at every 10 k now. i had it tested at 8000 miles of use and it was still in good condition
I'd rather be driving:
I just did my oil change today; used the new Mobil 1 Racing 0W-30. It's got a really high TBN so it'll easily go over 5K miles until the next oil change. The engine in the TL is super easy on oil so 7.5K on synthetic is a cakewalk.
New Life
I agree, I changed mine for Mobil 1 at 15K, so far I'm happy, feels like it runs smoother. Also I use K&N oil filter, I already put 2K over the 15K and I look at the oil and it looks like I just changed, great combo.
Castrol GTX comes in a 5/20wt. The local Kragens sells it for $1.99/qt and often has it for $1.49 with a coupon. I change the oil every 3K miles.
I am coming up to 30K and plan on doing the sevice the service. Change oil, oil filter, tranny fluid, clean/re-oil K&N air filter, rotate tires plus various "check this, inspect that". Dealer wants $390 - I don't think so.
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
