Oil catch can question ----help !!!
~~~ SKY'S THE LIMIT ~~~
so im wondering what the purpose is of a oil catch can
my friend gave me one and its pretty nice lookin and wondering how to install it on my 99 TL
what the advantages of having it ??
any advice wud be greatley appreciated----THANKS GUYS
I had one installed on my turbo eclipse in like 98 or 99 it pretty much catches the junk before it re enters the intake valves.
An oil catch can doesn't add any power or make any cool noises so it is often overlooked when modifying vehicles. However, a catch can will ensure you are always running the most power possible by having a cleaner intake tract free of oil.
Senior Airman
Check this thread: https://acurazine.com/forums/2g-cl-2001-2003-50/importance-oil-catch-can-717397/
to capture crankcase pressure venting you can use a small `can` with a filter material
to keep oil in it and allow only air to vent out
if it were not for that system the internal pressures created by ring bypass would explode the engine
its there for a reason!
Senior Airman
Are you talking about the existing system or the oil catch can setup? Are you saying that this is a bad or good mod? thanks.
Unregistered Member
Im not sure I understand what your saying. "if it were not for that system the internal pressures created by ring bypass would explode the engine"
As gas is burned in the cylinders, some of it is blown past the piston rings into the crankcase. This would build up pressure, and would cause a leak eventually.
To prevent this, the PCV system takes a portion of the intake air and runs it through the crankcase. This air is then released from the crankcase back into the intake manifold. The idea is that the air will trap all of the gas with it, allowing for the crankcase to keep a constant pressure inside.
However, sometimes the intake air will vomit, for the lack of a better term, back into the intake. When it does this, a little bit of oil will come with it. This means that oil will be regurgitated from the crankcase into the intake manifold, and the engine will burn oil.
The catch can is a tool that will allow air to pass, but "catch" any oil that is passed through. This way, the engine will still ventilate properly, but all of the oil is caught into the can. Every now and then, you just drain the catch can of the oil.
It seems like a smart idea to put it into all cars, but it is just extra production cost for regular drivers. The car only spits up oil back into the intake manifold during certain conditions. Usually, this happens during Wide Open Throttle. Tuners are at WOT a lot more than regular drivers, so they usually install a catch can for good measure.
If you have a super/turbo charger, I would assume a catch can would be necessary. The extra power created by these instruments can seriously increase the amount of blow by gasses that seep from the cylinders into the crankcase.
Someone please correct me if anything is wrong.
slowcl-s (07-19-2011)
A Catch Can have the benefits of being:
1.- Inexpensive
2.- Easy to Install
3.- Keeps IM, IACV, TB Clean
This is by far the best deal on Ebay (Im Buying It!):
http://cgi.ebay.com/ebaymotors/ANY-C...Q5fAccessories
Dont buy anything from overseas, It just screams Problems.
Note: On that Catch Can the little filter is Optional.
1.- Inexpensive
2.- Easy to Install
"Search Button"
so how wud i install it on my 99 TL---i mean specifics here----i completley understand the concept of it---just dont know how to install it
When i typed it in i got a bunch of results. Many showing pictures of where and how. 99TL - 03 CL doesnt matter same concept and motor and car(minus 2 doors).
BoricuaTL
04-08-2016 01:08 PM
IIDXholic
10-08-2015 07:53 AM
