Odometer backlight question
Old Aug 6, 2011 | 01:33 PM
Severin's Avatar
Question Odometer backlight question
I finally got around to changing my burnt out D5 bulb, only to find out after reassembly that the right-hand side of the odometer backlight is out now (I assume it was weak and got jostled just right). The temperature side is still good and bright.
My question is, is this bulb accessible from the rear of the cluster or do I need to disassemble the whole damn cluster and gauge assembly again?
Also, does anyone have the part number for the bulb?
Old Aug 6, 2011 | 02:01 PM
Severin's Avatar
I think I figured it out; there are three that are installed from the back of the cluster: 78181-S0K-A21
Old Aug 6, 2011 | 04:23 PM
Karanx7's Avatar
Unregistered Member
Yup, you got it. Odometer bulbs are easy peasy. And yea you're right, the weak bulbs tend to burn out when you replace something. Two ODO bulbs and my D5 bulb went out when I installed my gauges.
Old Aug 21, 2011 | 03:04 PM
dc2kid's Avatar
hey is there a diy for the d5 i did mine a while back and now mine keeps coming on and off i think it got loose and i can't find the diy anymore
Old Aug 22, 2011 | 09:40 AM
Severin's Avatar
There are links in the following threads for step-by-step instructions w/pics to remove the cluster and disassemble it:
https://acurazine.com/forums/showthr...1#post12991055
https://acurazine.com/forums/showthr...2&goto=newpost
Old Aug 22, 2011 | 01:35 PM
Karanx7's Avatar
Unregistered Member
Look a that, I wrote those. First time someone has linked my stuff.
Yaay, I am useful.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
