Odometer area is very dim
DIY Mad Scientist
I just purchased a 99 TL. I noticed that the Odometer area where the trip, odometer, temperature and door staus are is very dim. It's fine at night but I can't see anything during the day. Is this normal? Is there anything I can do to make this better?
DIY Mad Scientist
I took my shades off I swear! I see no difference when I turn my headlights on or off. I think something is broken... maybe a bulb or LED burnt out in the instrument panel.
Does the odometer area actually light up differently when the headlights are on and off?
there's a dial under the T/C button, Cruise control and all that cluster of buttons. You can either turn it right to left, that will adjust the brightness of the lights. If you can't see it during the day, then you definitely have a problem.
DIY Mad Scientist
Yup. The dial is at the brightest. It's perfect at night, but can hardly see any of it in the day. I hope to get my service manuals soon and I'll pop the cluster out and check the bulbs, etc. Thanks.
Strange -- this was also one of the first things I noticed when I got my '99... My friends just sort of laughed when I told them it bothered me. I always drive with my full lighting system on. However, during the day, I always completely dim the interior lights using the switch. I figure having the interior gauges lit during the day is only wasting the bulbs and using them up faster... I don't need the lights on to read the dash during the day anyway. I also think that Acura could've done a much better job at designing the pods where the gauges lay.. Had they made the surrounding a bit deeper (especially at the sides of the gauge pod), it would've helped a ton by blocking out the glare from the sun - making the bulbs more efficient. I also think it would be much easier to read if they'd chosen a brighter/lighter coloured bulb instead of that deep orange colour.
Boomer SOONER
when you turn on your headlights, your dash lights dim...I dont notice at all durring the day. Maybe cause I really never have my headlights on...why would you have them on durring the day?
I drive with my full lighting system on all the time because I had it set to go on automatically with start-up on my previous car and am used to always using the lights.... Studies have found that it's much safer to drive with your lights on --- the more visible you are: the better. ...That is why Canadian models have DRL - they found it reduced accidents. Honestly, it really does make cars more visible during the day - especially on bright, sunny days. I just take it a step up and throw on my tail lights as well (and regular headlights instead of DRL).
soupi
14
11-15-2015 11:15 AM
