Odd tire wear....
Old 01-26-2001 | 07:51 AM
TITAN3.2TL's Avatar
Angry Odd tire wear....
I need some opinions. I am getting some odd tire wear on the inner portion of my tires. It started out as a slight "wobble" and a "warped" whinning sound. The tires are only about 3 months old, and I have had Comptech springs add also. I did have the car realigned last month after the springs had been on there about a month and a half. I have also had the tries rotated regularly.
Do you guys have any suggestions?
This photo is "pre-mods"; "post-mods" photo coming......
1999 Acura 3.2TL
Black with Ebony
Bridgestone Potenza RE730 (size: 225/55ZR-16 on stock rims)
AEM Cold Air Intake and Bi-Pass Valve
Comptech Headers
Mugen Exhaust
Comptech Sport Springs
Comptech Swaybars
Old 01-26-2001 | 08:16 AM
NSX4dr's Avatar
Original Member #81
Post
It's possible you hit a nasty bump......I say get your alignment checked again....
Comptech exhaust
Comptech springs
custom air intake
18x7.5 Alstadts w/ 53mm offset (FOR SALE)
225/40/18 Kumho Ecsta Supras
Plastic on grill color matched
153mph Top Speed
192hp @ the wheels
Old 01-26-2001 | 11:08 AM
TITAN3.2TL's Avatar
Thumbs down
I had my alignment checked again this morning, and it is still within specs. The tire dealership said that the wider tires are what is causing the wear on the inside.
Does anyone else with 225/55 size tires have any problems with the insides wearing?
1999 Acura 3.2TL
Black with Ebony
Comptech Headers
Mugen Exhaust
Comptech Swaybars
Old 01-26-2001 | 11:11 AM
haha98's Avatar
Cool
maybe they are rubbing on something...
1996 2.5 TL Dark Green
HKS Powerflow, HKS Fuel Pressure Regulator, Sebring Exhaust, Jacobs Pro Street, Apex-i AFC, Jet ECU, Powerslot Rotors, Axxis Metal Master Pads, PIAA 1100x, Clarion 9255, Tube Driver Amps, Boston Pro 10's (2) , CD Technologies 6-4-2, Clarion MVA6491 (3), Valentine 1, Cliford Avant Guard 4, Monster Capacitors (2), Jacobs Accuvolt, Trunk, Underdash and Underbody Neons
No nav yet but soon!!!
Old 01-26-2001 | 11:13 AM
TITAN3.2TL's Avatar
Post
It's not rubbing. It is making a sort of wave or cupping on the inner tread of the all the tires?!?
Old 01-26-2001 | 11:35 AM
AcuraTL's Avatar
OG
Post
Could you take a picture of both front tires and post it up so we can see what you are talking about?
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
Old 01-26-2001 | 11:47 AM
TITAN3.2TL's Avatar
Post
It is not something you can really see, but if you run your hand along the tires you can feel it. It goes up and down almost like a roller coaster on a small scale.
Old 01-26-2001 | 04:08 PM
Guest
Guest
Posts: n/a
Post
Just a thought - not an expert - but don't you have to modify the offset specs when you widen a tire - ie - instead of x degrees - you might have to go to x+y degrees? I remember having to do something like this in the old days. I think because of the lowering and wider tires normal specs would not cut it. Who is doing your alignment? maybe a sport shop will be better to assit you? Just some thoughts - not an expert.
Old 01-26-2001 | 04:09 PM
Guest
Guest
Posts: n/a
Post
Old 01-26-2001 | 04:48 PM
AcuraTL's Avatar
OG
Post
If it is what you described, up and down like a rollercoaster. Your rims/tires, my friend, aren't balanced correctly. If your rims/tires aren't balanced, it will wear unevenly in spots.
Old 01-26-2001 | 05:28 PM
adamyankee's Avatar
Lightbulb
Tink makes a good point
adamyankee's Avatar
Talking
Tink makes a good point ... HA HA
Old 01-26-2001 | 05:51 PM
jhalderman's Avatar
Post
What you descibe sounds like typical "high speed cornering-type" tire wear. This is possible?
Old 01-26-2001 | 07:07 PM
AcuraTL's Avatar
OG
Post
If you read your manual, it will even tell you if your tire is worn unevenly like what TITAL3.2TL had described, it states it is caused by unbalanced wheel/tire.
DidiBob
01-04-2016 01:41 PM
Robospinner
22
09-24-2015 09:47 AM
CostcoFanAUS
09-18-2015 07:05 AM
fallacy
09-04-2015 11:15 AM
Quick Reply: Odd tire wear....
