OBD code returned by Autozone
7th Gear
Hi
I took my car to Autozone and they connected the compute and gave me the following code... P0401 9EGR Flow Insufficient). Does anybody has had this problem before? If yes what is the estimated cost to fix it.
Jeet
Jeet
Dragging knees in
PM fsttyms1. He's done it before, and he's the guy to ask.
If you're mechanically inclined, then you could have a tackle at it for a few hours.
Otherwise, take it to the dealership. It's a common problem, so they just might do it on goodwill.
As for an estimate cost -- I have no clue.
its a easy fix if you have a few simple hand tools and a hour to 2 to spend. the dealer will want to bend you over for something easy to do (if you feel comfortable taking a few things off your engine)
if you want more info let me know. ive done it twice now (about every 75k)
Egr
Check out my previous post on this subject. I just had this done a couple of months ago and it cost about $250. Basically there is a poorly designed part that allows this system to clog and sets off the light on the dash. If it is truely clogged, you will get decreased gas mileage and you would not be able to pass and e-Check (if applicable in your area). Check with your Acura dealer because there was a TSB about this and they are supposed to fix it under warranty until 80K I believe. To get it fixed, there are two options. You can just get it cleaned out (which ftty explains very well) or you can have Acura use a kit to replace the faulty part. This is slightly more expensive ($350 ish) but is better if you are planning to fix the car.
Sorry for the slightly disjointed response, but I'm in a hurry at work..
it take about 1hr or less for the dealer to do and 450+$$ and for a novice mechanic it would take under 2 hrs and cost him about 8 dollars in carb cleaner.
ive had it happen twice now (each time around 75,000+ miles. the first one wasnt covered under warranty the 2nd one i did my self. (i watched them do the firt one, so i knew it was easy and wasnt going to waste money on having them do it again)
6th Gear
erg passages clogged
Originally Posted by fsttyms1
last time it happened to me i was quoted 450+ to have the work done (cleaning and the egr pipe kit)
Had this problem, also, at 205000 miles ( 2000TL). Did the work myself. Dealer cost was $270.
Make sure you check and see if your dealer will do it for free. If you need to, make them feel bad about the tranny/rotors/seat belt/ whatever else you feel like complaining about. You can get it cleaned, but the problem can come back if it is not fixed.
Originally Posted by optomos
Just talked to acura dealer and they want 200 for the EGR and the local part store wants 178 for it. I guess I may as well change the bugger
Post #4
http://www.acurainspired.com/forums/...showtopic=4003
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
Boomer SOONER
Dragging knees in
Originally Posted by ou sig
believe fsttyms1 - mine did the same thing a while ago - after I took the intake manafold off, I could see that the EGR port was 100% clogged, it is all good now after I cleaned it and saved $100s
the P0401 code doenst mean you need to change the egr, you have clogged intake ports that need to be cleaned
Post #4
Post #4
Thanx. Ill try that. I did notice thought that it started to surge also, very slitely when at a red light. hopefully this will resolve it.
Jamus22
06-11-2023 10:08 AM
